While Playing Lineage 2, system BSODed and restarted twice, I disabled auto restart and enabled a complete memory dump. Loaded L2 again and once again it crashed a few minutes into the game.
Got DRIVER_IRQL_NOT_LESS_OR_EQUAL. (Cant remember the code that showed up. Think it was 0xD1, but I'm not sure anymore, didn't write it down at the time.) There was no other system file included in the BSOD.
Memory dump was at 76 when we had a blackout. I thought it would be alright, so I tried to turn it on when the power came back. All I got was black screen, no POST, no BIOS but LED lights and fans are on.
PC is about a year old. Everything is at stock settings. Been running smoothly for the whole year. Bought a new Video card, Inno3D 9600GT 512ddr3, 2.5 weeks ago, and been using it with L2 since with no problems. It just started crashing sunday. Was at a convention, so didn't have time to fix it until now.
System right now is breadboarded on my desk. Stripped down to just HSF and PSU. Gonna wait for advice from you guys.
CPU - Celeron D 420 1.6Ghz
Motherboard - Inno3D SL7N73VM (http://www.inno3d.com/products/motherboard/SL7N73VM.html)
RAM - Corsair 1GB PC2-5300 ValueSelect 5-5-5-15 (stock settings)
Video Card - Inno3D 9600GT 512DDR3 (stock settings)
Power Supply - iMaster Pro 550w (26A at +12v rail - minimum requirement for the 9600GT)
The PC was originally bought mostly for work and some video editting. The build wasn't really for gaming. Bought the vid card originally to play the AION Chinese CBT, but had no time. L2 was the only game I played on it.
I'm leaning towards a busted board or inadequate PSU, but it was running fine for 2.5 weeks, so I'm kinda waiting for recommendations or advise on how to fix it before I go buy new parts. The PSU is quite new. Just a month old, and the store said it was good enough for the 9600GT. And it was working like a charm the whole time.
Steps I tried to fix:
1. Strip down everything except for HSF and PSU.
2. Shorted the power on.
3. LEDs and Fans came on, no POST.
4. Shorted it off.
5. Plugged a system speaker into the JSPEAKER 4-pin set, the board doesn't have a built-in speaker. (Manual said this was only for the case internal speakers. But there isn't any POST speaker, so I kinda hoped it would work.) No beeps.
Should also note that I had checked the drivers with a free scan from Uniblue's Driver Scanner last friday, it said I was all up to date. Need advice badly.
Thanks a lot.
4. Shorted it off.
Thanks a lot.
