Hi guys, I'm in a dilemma and would like opinions to decide which one to go for.
I'm going for a Lenovo legion gaming laptop 2021 edition, and currently there are 2 options
1) Lenovo legion 5 -Ryzen 7 5800 - RTX 3070 - 16GB RAM - 512GB SSD
Screen 15.6" 1080p 165HZ 300nits 16:9 ratio
Price = £1,115
2) Lenovo legion 5i Pro - i7 - 11800H ,RTX 3060, 16GB RAM , 512gb SSD
Screen - 16" 2560x1600p 500nits , 16:10 ratio 165hz
Price = £1,254
Difference between the two = around £140
With that settled I'm not sure which ones the better option,
on one hand the base legion 5 has an RTX 3070 and it's cheaper, but the screen is worse
On the other hand the 5i pro, has a brilliant 16.10 ratio screen, quad hd, and 500 nits of brightness , but it then has the weaker GPU, although fps wise it isn't highley different, I'm just thinking about the vram Of 6Gb to be suitable for 1600p for 3-4 years.
I plan to game demanding games , with rtx, and I guess I will be using dlss
What do you think,? Perhaps someone has either 1 of the 2 versions of the legion who can give a little insight ?
Price = £1,115
Price = £1,254
