LG E2251 Super LED Flatron Monitor - gaming issues.
deadfish
130
Hello,
My LG E2251 Super LED Flatron Monitor I am nearly convinced is causing me some severe lag / display issues during startup of computer games that are graphic intensive.
I have a 560 GX twinfrozer graphics card by MSI. ,3.2 CPU, 4 gigs ram.
Prior to purchasing this monitor I had a 17in flat generic monitor that played everything with no fuss.
Since getting something that can display at 1920x1080 natively. Almost all games startup just fine, then shortly after become very slow/freeze/crashing.
It should be unnecessary to reinstall all my games dont you think?
I have played around with the settings but all seem to simply crash eventually, act incredibly slow, black screen, or zero response from the keyboard. I have changed to 1024x780 and made sure that the refresh was within 60Mhz, as this is what the monitor can handle.
Nividia drivers are the latest, and I have also tried going back to a previous version.
Other news - I did upgrade the generic keyboard to a Logitech G105 blue led "gamer" keyboard. Could it be this too?
really sad about upgrading and feeling like I actually downgraded.
Thanks in advance for any advice.
UPDATE
I used a program to read the following
Maybe posting this, someone can see if my monitor is failing to post the correct resolution? Or something else. Thanks in advance.
EDID ( Extended Display Identification Data) Report
Vendor/Product Identification:
Monitor Name : E2251
Monitor Serial Number : 201LTWV1V569
Manufacturer Name : LG Electronics Inc. (GoldStar Technology, Inc.)
Product Id : 586E
Serial Number : 63569
Week Of Manufacture : 1
Year Of Manufacture : 2012
EDIDVersion : V1.3
Number Of Extension Flag : 0
Display parameters:
Video Input Definition : Digital Signal
DFP1X Compatible Interface : False
Max Horizontal Image Size : 480 mm
Max Vertical Image Size : 270 mm
Max Display Size : 21.7 Inches
Power Management and Features:
Standby : Supported
Suspend : Supported
ActiveOff : Supported
Video Input : 1
sRGB Default ColorSpace : False
Default GTF : Not Supported
Prefered Timing Mode : True
Gamma/Color and Etablished Timings:
Display Gamma : 2.2
Red : x = 0.642 - y = 0.332
Green : x = 0.305 - y = 0.625
Blue : x = 0.15 - y = 0.068
White : x = 0.313 - y = 0.329
Etablished Timings :
800 x 600 @ 60Hz (VESA)
640 x 480 @ 75Hz (VESA)
640 x 480 @ 60Hz (IBM, VGA)
720 x 400 @ 70Hz (IBM, VGA)
1280 x 1024 @ 75Hz (VESA)
1024 x 768 @ 75Hz (VESA)
1024 x 768 @ 60Hz (VESA)
800 x 600 @ 75Hz (VESA)
Display Type : RGB Color Display
Standard Timing:
Standard Timings n° 1
X Resolution : 1152
Y Resolution : 864
Vertical Frequency : 75
Standard Timings n° 2
X Resolution : 1280
Y Resolution : 1024
Vertical Frequency : 60
Standard Timings n° 3
X Resolution : 1280
Y Resolution : 1024
Preferred Detailed Timing:
Pixel Clock : 148.5 Mhz
Horizontal Active : 1920 pixels
Horizontal Blanking : 280 pixels
Horizontal Sync Offset : 88 pixels
Horizontal Sync Pulse Width : 44 pixels
Horizontal Border : 0 pixels
Horizontal Size : 477 mm
Vertical Active : 1080 lines
Vertical Blanking : 45 lines
Vertical Sync Offset : 4 lines
Vertical Sync Pulse Width : 5 lines
Vertical Border : 0 lines
Vertical Size : 268 mm
Input Type : Digital Separate
Interlaced : False
VerticalPolarity : True
HorizontalPolarity : True
Monitor Range Limit:
Maximum Vertical Frequency : 75 Hz
Minimum Vertical Frequency : 56 Hz
Maximum Horizontal Frequency : 83 KHz
Minimum Horizontal Frequency : 30 KHz
Maximum Pixel Clock : 150 MHz
Stereo Display:
Stereo Display : Normal display (no stereo)
RAW Data:
0x00 00 FF FF FF FF FF FF 00 1E 6D 6E 58 51 F8 00 00
0x10 01 16 01 03 80 30 1B 78 EA 40 A5 A4 55 4E A0 26
0x20 11 50 54 A5 4B 00 71 4F 81 80 81 8F B3 00 01 01
0x30 01 01 01 01 01 01 02 3A 80 18 71 38 2D 40 58 2C
0x40 45 00 DD 0C 11 00 00 1E 00 00 00 FD 00 38 4B 1E
0x50 53 0F 00 0A 20 20 20 20 20 20 00 00 00 FC 00 45
0x60 32 32 35 31 0A 20 20 20 20 20 20 20 00 00 00 FF
0x70 00 32 30 31 4C 54 57 56 31 56 35 36 39 0A 00 63
