LG monitor
G
Guest
Guest
ok i posted about my newly bought LG FLATRON 795ft+ well after attempting to adjust the allignment of the electron guns to no avail, the monitor is in my opinion certified a dud i will now be taking LG on that 3 year warranty swap out gaureentee :):):)
The moniter is superd apart from this problem i have endured unforntunately !!! anyone have a LG FLATRON do they all have allignment problems or was my model just a one off and are there any optimal settings i should try out or how do i adjust the osd to fix such problems !!!???
I have the 915Ft Plus. I think the problem might be the concavity of the screen? They're all that way. You get used to it after a while.
"If you teach a child to read, then he or her will be able to pass a literacy test" - George W.
