G
Guest
Guest
Archived from groups: alt.comp.periphs.mainboard.asus (More info?)
I used the m/b's usb connector to enable 2 of the front usb ports(USB 1.1)
on my Lian-Li PC60 case.
I experienced a number of problems including:
After removing a usb flash memory device I could no
longer access drives in windows explorer
After shutting down normally and later restarting,
Windows XP Pro would "hang" at the intro screen
(i..e, the one with the moving bar at the bottom).
By hitting reset and starting over from there system
booted normally.
My card reader could not be detected.
I disconnected the front usb connectors and all returned to normal,
including being able to use the extra usb's on
the game port.
Any ideas on troubleshooting this ......ie., to be able to use the front USB
ports.
booted normally.
the game port.
ports.
