G
Guest
Guest
Archived from groups: alt.comp.periphs.mainboard.asus (More info?)
I am posting this here since I am certain that many of you are using
Lian-Li cases.
My question is about the two front fans. These are 3 wire fans
connected to a small 3 switch circuit board with resistors that
controls the speed of both fans. My understanding on fan speed control
in general, is that by varying the voltage to the red fan lead
(usually connected to the yellow 12V Molex) one controls the speed,
The third wire, in general, (blue or yellow) is used for speed
monitoring, not for speed control.
However, the Lian-Li front fans are 3 wire and all are connected to
the small circuit board. There is no fan speed monitoring that I can
determine. My questions are:
1. How is the speed controlled in the Lian-Li ... by varying
voltage or by some other method using that third wire??
2. Are these special fans with the third wire (blue) set up to
control speed rather than monitor speed?
Norm
Lian-Li cases.
Norm
