Hey there,
The power indicator light on my case was working fine for the first couple of weeks of use, and now it just blinks blue when I press it to start up the PC, and then goes dark. I don't believe that I've changed any settings anywhere, so I'm not really sure why it's doing this.
The Power LED pins are plugged in correctly on the motherboard. (At least, they should be. I haven't changed their orientation since the light worked so...)
Any help would be appreciated, thanks
Edit: Looks like my brother was messing with my BIOS settings. Lighting was set to "Aura Only" instead of "All On." It's fixed now 😀
