I've recently installed a liquid cooling loop into my pc to replace my previous air cooling unit for my cpu. With my previous air cooler, I was seeing idle temperatures around 35C. With the liquid cooling, I'm seeing temperatures around 45-50C at idle and 65C under stress (running cinebench). From what I've read, the goal for idle temps should be around 25-35C. My ambient room temp is at 25C and system temps are around 30-36C.
What can I do to improve my idle cpu temperatures? While I was not expecting a significant increase in cpu temps switching from air to liquid, I was not expecting it to get this much worse.
Technical details about my build:
- CPU = AMD Ryzen 7 3700X (PC Part Picker full build list)
- Case = NZXT 510 (compact mid-tower)
- previous cpu air cooler was the AMD Wraith Prism cooler that came with the cpu. There were no intake fans, just 2 exhaust fans in this setup.
- Liquid cooling loop is the EKFluidGaming A240 kit with custom hard tubing and EK fittings
- Radiator is positioned in the front with 2 120mm Vardar static pressure fans positioned in a pull configuration (fans and rad came with A240 kit)
- No overclocking or custom configs are being used for the cpu. I'm using the same default stock config that was being used for the air cooling setup.
- Pump is definitely on and working. Aside from vibrations coming from pump, this is supported by the fact that temperature also sits at ~48C rather than continuing to increase in temperature every couple of seconds.
- Fan direction is correct
- From what I can tell, loop is free of air except for a few bubbles trapped in the reservoir. I tilted the system a bunch to try and free any bubbles trapped in the rad and cpu block.
- Radiator is slightly warm to the touch, but otherwise is mostly cool with cool air being pulled into it.
- Thumbscrews on cpu block are tightened sufficiently.
- Appropriate amount of thermal paste (EK-TIM Ectotherm that was enclosed with A240 kit) was used and inline with online recommendations (2 rice grains/size of a pea).
