Hey there all.
Saw the 5ghz project, and the recent 8ghz breakthrough, both using liquid nitrogen.
The problem for liquid nitrogen that it evaporates immediately means its logistically unsustainable unless a closed circulatory system is implemented, but (A) what would happen if you kept your entire board with peripheries (including HDD'd but not DVD-RW's etc) in liquid nitrogen the entire time? Would the structural integrity be compromised with the thermal contractions and expansions from prolonged exposure vs heat of use?, and (B) can one safely create a closed system with all necessary wiring coming from within the system to the outside, without coolant leak around the seals for the wiring? What type of sealant would one use to stop ssuch event?
I must confess that I do not know much about liquid nitrogen, but it seems to be the best in terms of keeping one's rig ultimately chilly.
