Little advice on a build?
My humble suggestion:
CPU: Intel Core i3-4150 3.5GHz Dual-Core Processor ($104.75 @ OutletPC)
Motherboard: MSI H81M-P33 Micro ATX LGA1150 Motherboard ($41.98 @ Newegg)
Memory: Kingston Fury Series 8GB (2 x 4GB) DDR3-1866 Memory ($64.99 @ Amazon)
Video Card: MSI Radeon R7 250X 2GB Video Card ($73.99 @ SuperBiiz)
Case: Thermaltake VL80001W2Z ATX Mid Tower Case ($19.99 @ Micro Center)
Power Supply: EVGA 500W 80+ Certified ATX Power Supply ($24.99 @ NCIX US)
Total: $330.69
Generated by...
clearly you're out your mind recommending 250x for new titles and worst you advice full hd resolution. r7 260x is having a hard time with new titles in 1080p gaming, what more a lower model. Better do your research first bro
Yeah, me and all the professional reviewers that like the card are out of our mind's...all the benchmarks that show games running at 40-60 FPS @1080 are crazy (like the one you quoted from me)
You're making a heavily biased statement just because the card doesn't run games the way you want to run them. That doesn't help the OP, or anyone else for that matter.
Oh look, here's tom's hardware best GPU's list for Feb recommending the card...
http://www.tomshardware.com/reviews/gaming-graphics-card-review,3107-2.html
ok so you recommend this card in 1080p and as the OP wants it NO LAGGING. Try running this with far cry 4 in 1080p and with NO LAG. I guess you missed that part where OP said NO LAGGING in new titles ha? Still can't imagine a card like this being recommended for 1080p gaming. Its crazy
Yeah, and 42 FPS minimum, meaning he can turn it up and still stay above 30 fps at all times.
Also, the OP didn't specify what settings he wants to run at. You made that up.
That is a horrible PSU. If you cannot afford a new one, I would switch the GPU to a GTX 750 or 750ti.
CPU: AMD FX-6300 3.5GHz 6-Core Processor ($94.99 @ SuperBiiz)
Motherboard: Gigabyte GA-78LMT-USB3 Micro ATX AM3+ Motherboard ($54.99 @ Micro Center)
Memory: Kingston Fury Series 8GB (2 x 4GB) DDR3-1866 Memory ($61.00)
Video Card: Zotac GeForce GTX 750 1GB Video Card ($94.99 @ SuperBiiz)
Case: Xigmatek Recon ATX Mid Tower Case ($29.99 @ Newegg)
Total: $335.96
Generated by PCPartPicker 2015-02-26 11:29 EST-0500
Better to upgrade psu first before upgrading your gpu. That psu won't hold up even with 250x
Total: $330.69
Generated by PCPartPicker 2015-02-26 11:41 EST-0500
Cheers!
My first thought was to go with an I3 but after reading, I hear a lot of opinions regarding the dual core being an issue in the near future. Maybe go with that build for now and look into upgrading to an I5 on the same board later?
Dual thread will be an issue in the near future, yes. That's why I recommend the I3 and not the G3258. I3's use hyperthreading, allowing them to run 4 threads simultaneously.
The FX chips are great value if you're willing to overclock., but I recommend intel platforms for people who aren't comfortable with overclocking and/or and/or want a long upgrade path.
As much as I dislike that PSU, it isn't probably any worse than the junk OEM's use. I would go with this, and then change that PSU, ASAP.
CPU: Intel Core i3-4130 3.4GHz Dual-Core Processor ($104.95 @ SuperBiiz)
Memory: G.Skill Ripjaws Series 8GB (2 x 4GB) DDR3-1600 Memory ($59.99 @ Newegg)
Case: NZXT Source 210 (Black) ATX Mid Tower Case ($37.99 @ SuperBiiz)
Total: $339.90
Generated by PCPartPicker 2015-02-26 13:43 EST-0500
