load temps for 1.6vcore winchester
roy
498
Archived from groups: alt.comp.periphs.mainboard.msi-microstar (More info?)
I finally got around to upping the vcore on my system and overclocking a
little. My idle temps are right around 40c and my load temps are around 55c
with 1.6vcore. Just wondering if this is normal for winchester cores. I
had to raise the vdimm to 2.85 to achieve stable timings of 1:1, 1T,
2.5-3-3-10, at 278Mhz. Ram is G.Skill PC4400 DDR550 512MB x 2 (dual
channel)
rest of system specs
AMD Athlon 64 3000+ 939 90nm Winchester 1.8Ghz oc'd to 2.5Ghz, 9x, 278htt,
3ht
ThermalTake Silent Tower CL-P0025
MSI K8N Neo 2 Plat Model 7025 Bios 1.41 (beta)
BFG Nvidia GeForce FX 5900XT OC
Core Clock 430Mhz (vs 390Mhz standard)
Mem Clock 735Mhz Effective
Drivers 66.93
Lian Li Aluminum ATX Mid Tower Case PC-V1000
MGE Vigor 500 PSVG-500 500w Power Supply
Maxtor 160GB 7200RPM 8MG IDE ATA133 6Y160P0 x 2 (Raid - 0)
LG Electronics Dual layer DVD+/-R+/-RW Drive
HP L2335 23" Widescreen Flat Panel Monitor
WinXP Pro
DX 9.0c
"Roy" <a@a.a> wrote in message news:NXnCd.10151$%K5.8196@fe04.lga...
>55c with 1.6vcore. Just wondering if this is normal for winchester cores.
Its a bit high, but nothing outrageous. 1.6v is quite a lot for a
Winchester, so that would explain it.
For a reference, I get 52C running Prime95 at 10x250 at 1.5v CPU.
Chip
