Login problems
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.basics (More info?)
Hello all
I am having problems with logon it comes up with an error userinit.exe not found then a wording
along the lines of the procedure entry point setapi cm_disable_devnock could not be located in the
dll library
also CFMGR.32.dll comes up then !!
with the message the ordinal 5.2 could not be located in dll library shell32.dll please help me
I am desperate
cheers
Tony
Try a Repair Install as follows:
NOTE, while a repair install should leave your data files intact, if
something goes wrong during the repair install, you may be forced to start
over and do a clean install of XP. If you don't have your data backed up,
you would lose your data should that eventuality occur.
Assuming your system is set to boot from the CD-ROM drive and you have an
actual XP CD as opposed to a recovery CD, boot with the XP
CD in the drive and perform a repair install as outlined below. If the
system isn't set to boot from the CD or you are not sure, you need to enter
the system's BIOS. When you boot the system, the first screen usually has
instructions that if you wish to enter set press a specific key, when you
see that, do so. Then you will have to navigate to the boot sequence, if
the CD-ROM drive is not first line, set it first in the boot sequence. Save
your settings and exit with the XP CD in the drive. The system will reboot.
When the system boots, a few screens into the process you may see a message
instructing you
to hit any key in order to boot from the CD along with a countdown. When
you see this be sure to
hit a key on the keyboard, if you miss this instruction and the system fails
to boot from the CD, it's too
late, you'll need to reboot and try again.
Once you have pressed a key, setup should begin. You will see a reference
asking if you need to load special drivers and another notice that if you
wish to begin the ASR (Automatic Recovery Console) depress F2. Just let
setup run past all of that. It will continue to load files and drivers.
Then it will bring you to a screen. Eventually, you will come to a screen
with the option to (1) setup Windows or (2) Repair Windows Installation
using the Recovery console. ***The selection you want at this screen is
"Setup Windows,"
NOT "Repair Windows Installation.
The first option, to setup Windows is the one you want and requires you to
press enter. When asked, press F8 to accept the end user agreement. Setup
will then search for previous versions of Windows. Upon finding your
version, it will ask if you wish to Repair your current installation or
install fresh. Press R, that will run a repair installation. From there
on, follow the screens.
Note, in some cases, you won't receive the repair option, only an option to
reinstall. We have discovered that sometimes this is caused by damaged
boot.ini file that can be repaired as follows and also note, in the
instructions, "K" refers to the CD drive in which you have placed the XP CD,
replace that drive letter with the appropriate letter on your system, "K" is
simply an example.
Reboot, this time taking the immediate R option (this is the section I told
you to skip above. In this case, you will need to get to the Recovery
Console to perform the function below), and if the CD letter is say K: give
these commands
COPY K:\i386\ntldr C:
COPY K:\i386\ntdetect.com C:
(two other files needed - just in case)
ATTRIB -H -R -S C:\boot.ini
DEL C:\boot.ini
BootCfg /Rebuild
Once you've completed this function, reboot and see if you can access XP as
sometimes, the problem is the damaged boot.ini. If you still cannot access
XP, then reboot and re-run the repair install instructions at the beginning
of this message.
If you only have a recovery CD, your options are quite limited. You can
either purchase a retail version of XP which will allow you to perform the
above
among other tools and options it has or you can run your system recovery
routine with the Recovery CD which will likely wipe your drive, deleting all
files but will restore your setup to factory fresh condition.
Michael Solomon MS-MVP
Windows Shell/User
Backup is a PC User's Best Friend
DTS-L.Org: http://www.dts-l.org/
"Anthony Farmer" <farmer2000@iprimus.com.au> wrote in message
news:eo0h%234KrEHA.3728@TK2MSFTNGP09.phx.gbl...
> Hello all
> dll library
> I am desperate
> cheers
> Tony
Hello Michael just a little note I tried to reinstall it came up with same problem I have included
a hijack this log for you to look at you might be able to see something here mate cheers
Tony
Logfile of HijackThis v1.97.7
Scan saved at 11:36:22, on 09/10/04
Platform: Windows XP SP1 (WinNT 5.01.2600)
MSIE: Internet Explorer v6.00 SP1 (6.00.2800.1106)
Running processes:
C:\WIN\System32\smss.exe
C:\WIN\system32\winlogon.exe
C:\WIN\system32\services.exe
C:\WIN\system32\lsass.exe
C:\WIN\system32\svchost.exe
C:\WIN\System32\svchost.exe
C:\WIN\system32\spoolsv.exe
E:\PROGRA~1\Grisoft\AVG6\avgserv.exe
E:\Program Files\mst software\mst Defrag\mstDfrgS.exe
C:\WIN\Explorer.EXE
E:\PROGRA~1\Grisoft\AVG6\avgcc32.exe
C:\Program Files\Internet Explorer\IEXPLORE.EXE
C:\Program Files\TuneUp Utilities\Integrator.exe
C:\Documents and Settings\All Users\Desktop\My Briefcase\COOL STUFF\HijackThis.exe
R0 - HKCU\Software\Microsoft\Internet Explorer\Main,Start Page = http://www.realfooty.theage.com.au/
R1 - HKCU\Software\Microsoft\Internet Explorer\Main,Default_Page_URL =
http://mirror.bom.gov.au/products/IDR503.shtml
R1 - HKCU\Software\Microsoft\Internet Explorer\Main,Window Title =
"""" THE FARMERS"""""""""
R1 - HKCU\Software\Microsoft\Windows\CurrentVersion\Internet Settings,ProxyServer =
proxy.iprimus.com.au:8080
R0 - HKCU\Software\Microsoft\Internet Explorer\Main,Local Page =
F2 - REG:system.ini: UserInit=C:\WIN\system32\userinit.exe,D:\OUTLOOK\EN\NT4SP3\I386\USERINIT.EXE
O2 - BHO: (no name) - {AA58ED58-01DD-4d91-8333-CF10577473F7} - c:\program
files\google\googletoolbar2.dll
O3 - Toolbar: &Radio - {8E718888-423F-11D2-876E-00A0C9082467} - C:\WIN\System32\msdxm.ocx
O3 - Toolbar: &Google - {2318C2B1-4965-11d4-9B18-009027A5CD4F} - c:\program
O4 - HKLM\..\Run: [AVG_CC] E:\PROGRA~1\Grisoft\AVG6\avgcc32.exe /STARTUP
O6 - HKCU\Software\Policies\Microsoft\Internet Explorer\Restrictions present
O6 - HKCU\Software\Policies\Microsoft\Internet Explorer\Control Panel present
O6 - HKLM\Software\Policies\Microsoft\Internet Explorer\Control Panel present
O8 - Extra context menu item: E&xport to Microsoft Excel - res://E:\MICROS~1\Office10\EXCEL.EXE/3000
O9 - Extra 'Tools' menuitem: Sun Java Console (HKLM)
O9 - Extra button: Net2Phone (HKLM)
O9 - Extra 'Tools' menuitem: Net2Phone (HKLM)
O12 - Plugin for .ips: E:\PROGRA~1\PLUS!\MICROS~1\PLUGINS\NpIpx32.dll
O13 - WWW. Prefix: http://
O16 - DPF: ConferenceRoom Java Client - http://chat.bigpond.com/java/cr.cab
O16 - DPF: Yahoo! Chat - http://us.chat1.yimg.com/us.yimg.com/i/chat/applet/c381/chat.cab
O16 - DPF: {01FE8D0A-51AD-459B-B62B-85E135128B32} (DD_v4.DDv4) - http://www.drivershq.com/DD_v4.CAB
O16 - DPF: {02BCC737-B171-4746-94C9-0D8A0B2C0089} (Microsoft Office Template and Media Control) -
http://office.microsoft.com/templates/ieawsdc.cab
O16 - DPF: {02BF25D5-8C17-4B23-BC80-D3488ABDDC6B} (QuickTime Object) -
http://www.apple.com/qtactivex/qtplugin.cab
O16 - DPF: {0E5F0222-96B9-11D3-8997-00104BD12D94} (PCPitstop Utility) -
http://pcpitstop.com/pcpitstop/PCPitStop.CAB
O16 - DPF: {11260943-421B-11D0-8EAC-0000C07D88CF} (IPIX ActiveX Control) -
http://www.ipix.com/viewers/ipixx.cab
O16 - DPF: {166B1BCA-3F9C-11CF-8075-444553540000} (Shockwave ActiveX Control) -
http://download.macromedia.com/pub/shockwave/cabs/director/sw.cab
O16 - DPF: {1842B0EE-B597-11D4-8997-00104BD12D94} (iCC Class) -
http://pcpitstop.com/internet/pcpConnCheck.cab
O16 - DPF: {23B7A816-3647-49D2-9756-6F41CE8F9201} (ddm_download.ddm_control) -
http://download.rfwnad.com/cab/ddm_control.CAB
O16 - DPF: {2B323CD9-50E3-11D3-9466-00A0C9700498} (Yahoo! Audio Conferencing) -
http://us.chat1.yimg.com/us.yimg.com/i/chat/applet/v45/yacscom.cab
O16 - DPF: {2BC66F54-93A8-11D3-BEB6-00105AA9B6AE} (Symantec AntiVirus scanner) -
http://security.symantec.com/sscv6/SharedContent/vc/bin/AvSniff.cab
O16 - DPF: {2DA4FB22-C308-11D3-86E5-00105AD18ACB} - http://www.gator.com/download/0980/iegator.cab
O16 - DPF: {30528230-99F7-4BB4-88D8-FA1D4F56A2AB} (YInstStarter Class) -
http://download.yahoo.com/dl/installs/yinst0401.cab
O16 - DPF: {3E68E405-C6DE-49FF-83AE-41EE9F4C36CE} (Office Update Installation Engine) -
http://office.microsoft.com/officeupdate/content/opuc.cab
O16 - DPF: {4855C21B-E452-4661-A702-ED3493CE74DF} -
http://sp.ask.com/docs/toolbar/download/askbar-inst.cab
O16 - DPF: {56ECEF01-E59E-11D0-9243-000000000000} (ViewPixCtrl01 Class) -
http://image.photoloft.com/OpenPix/controls/ViewPix01.CAB
O16 - DPF: {6414512B-B978-451D-A0D8-FCFDF33E833C} (WUWebControl Class) -
http://v5.windowsupdate.microsoft.com/v5consumer/V5Controls/en/x86/client/wuweb_site.cab?1096496537427
O16 - DPF: {644E432F-49D3-41A1-8DD5-E099162EEEC5} (Symantec RuFSI Utility Class) -
http://security.symantec.com/sscv6/SharedContent/common/bin/cabsa.cab
O16 - DPF: {74D05D43-3236-11D4-BDCD-00C04F9A3B61} (HouseCall Control) -
http://a840.g.akamai.net/7/840/537/2004061001/housecall.trendmicro.com/housecall/xscan53.cab
O16 - DPF: {7D1E9C49-BD6A-11D3-87A8-009027A35D73} (Yahoo! Audio UI1) -
http://chat.yahoo.com/cab/yacsui.cab
O16 - DPF: {8714912E-380D-11D5-B8AA-00D0B78F3D48} (Yahoo! Webcam Upload Wrapper) -
http://chat.yahoo.com/cab/yuplapp.cab
O16 - DPF: {8FBFE5FF-5E98-11D3-80AF-00C04FCFBC72} (SurveyCtl35 Class) -
http://activex.microsoft.com/controls/mtswizards/sw35.cab
O16 - DPF: {90C9629E-CD32-11D3-BBFB-00105A1F0D68} (InstallShield International Setup Player) -
http://www.installengine.com/engine/isetup.cab
O16 - DPF: {9732FB42-C321-11D1-836F-00A0C993F125} (mhLabel Class) - http://pcpitstop.com/mhLbl.cab
O16 - DPF: {9F1C11AA-197B-4942-BA54-47A8489BB47F} -
http://v4.windowsupdate.microsoft.com/CAB/x86/ansi/iuctl.CAB?37867.9867476852
O16 - DPF: {A8658086-E6AC-4957-BC8E-7D54A7E8A78E} (SassCln Object) -
http://www.microsoft.com/security/controls/SassCln.CAB
O16 - DPF: {A8F2B9BD-A6A0-486A-9744-18920D898429} (ScorchPlugin Class) -
http://www.sibelius.com/download/software/win/ActiveXPlugin.cab
O16 - DPF: {B8D69BC3-E4DE-11D1-9BA1-0000C006B0D8} (National Internet Banking Images) -
http://www.national.com.au/rib/afs/v3002/cabinet/images.cab
O16 - DPF: {B9191F79-5613-4C76-AA2A-398534BB8999} -
http://us.dl1.yimg.com/download.yahoo.com/dl/installs/suite/yautocomplete.cab
O16 - DPF: {C2FCEF52-ACE9-11D3-BEBD-00105AA9B6AE} (Symantec RuFSI Registry Information Class) -
O16 - DPF: {D27CDB6E-AE6D-11CF-96B8-444553540000} (Shockwave Flash Object) -
http://download.macromedia.com/pub/shockwave/cabs/flash/swflash.cab
O16 - DPF: {E936C500-D12E-11D2-9E4D-0080C84BBDBB} (National Internet Banking Custom) -
http://www.national.com.au/rib/afs/v3002/cabinet/NABcustom.cab
O16 - DPF: {EA1B8527-E422-4909-825A-70BE0694F18E} (PortfolioManagerWT Profile Manager Class) -
https://westpaconline.com.au/pbs/WTBalanceSheet/portfoliomanagerwt.cab
O16 - DPF: {F5192746-22D6-41BD-9D2D-1E75D14FBD3C} - http://216.65.38.226/crack.CAB
O16 - DPF: {F5820AD3-9B20-423E-B2AA-7AF2B4055746} (CRegistryDownload Class) -
http://download.paltalk.com/download/0.x/regdload.cab
O16 - DPF: {F58E1CEF-A068-4C15-BA5E-587CAF3EE8C6} (MSN Chat Control 4.5) -
http://fdl.msn.com/public/chat/msnchat45.cab
O16 - DPF: {F72A7B0E-0DD8-11D1-BD6E-00AA00B92AF1} (IE Active Setup Control) -
http://www.microsoft.com/windows/ie/ie40/download/cdf/setupctl.cab
Nothing really stands out though I'm unfamiliar with TuneUp
Utilities\Integrator. As this is third party software, if the app is not
specifically the problem maybe something you've done with the application to
tune the system is the source of the problem.
Windows Shell/User
news:uPKSMGarEHA.1992@TK2MSFTNGP09.phx.gbl...
> here mate cheers
> Tony
> Running processes:
> C:\WIN\Explorer.EXE
> c:\program
> present
> present
> present
> Control) -
> Conferencing) -
> scanner) -
> Class) -
> Wrapper) -
> Banking Images) -
> Object) -
> Banking Custom) -
> Class) -
> Control) -
