I can connect my Logitech joystick to the front and back USB 2.0 ports and the joystick works but it will not work on USB 3.0 ports i dont know why its not being detected
Well, if it works on the USB 2 ports, what is the issue with using it on the ports that work? Did you check with Logitech support? Maybe the thing just does not like USB 3 specs.
