I like to replace my 8 port Netgear switch with a POE model. I run currently two POE AP's and one cam of this switch with injectors. I like to end-up with a cleaner setup not using injectors and several power supplies. I really need 8 ports at the current location. Some extra woudl be a plus. Realizing that usually the next "size" is 16 ports which typically results with a fan I like to avoid.
While I typically bought some sort of smart managed switch I rarely configure a switch.
I like a reliable brand/product
Here are some finds:
Netgear GC510p managed
https://www.cdw.com/product/netgear...ed-smart-cloud-switch-134w-poe-gc510p/4773524
Tripplite 8 port un-mangaed
https://www.tripplite.com/8-port-10...mount-desktop-gbe-unmanaged-switch-poe~NG8POE
BVTech un-managed 9 port:
https://www.amazon.com/BV-Tech-Port...D09RPW6YTXS&psc=1&refRID=XW8D90CY4D09RPW6YTXS
Unifi
www.ui.com
(I use unifi AP's, so this woudl seem to make sense, but reviews are not good)
Zyxel GS 1920
https://sviko.com/t/zyxel-gs-1920-8hp-v2-review-testing-cloud-poe-switch/40
Trendnet TPE-1020WS 10-Port:
https://www.newegg.com/trendnet-tpe...red-sfp/p/N82E16833156460?Item=9SIA0ZX21P7376
Would appreciate input on other models and feedback on the ones I listed. Not sure if I should add a Cisco model? I found the 250 and 350; however both with external PSU - but if I am not mistaken a true (usable) 10 port?
Unifi
Switch 8 PoE (150W)
An eight-port, Layer 2 PoE switch with a fanless cooling system. Features: (8) GbE, PoE+ RJ45 ports* (2) 1G SFP ports 130W total PoE availability Managed with the UniFi Network application *Also offers 24V passive PoE support.
Zyxel GS 1920
