Looking for a low-ish budget 1080p monitor
  • Thread starter Thread starter Deleted member 1210213
  • Start date Start date
D
Guest
1. What Is Your Country Of Origin? UK
2. What do you plan to do with this monitor? Games
3. What resolution and screen size do you want? 21.5-24 inch 1920x1080
4. What refresh rate do you want? >60hz
5. How much are you looking to spend?75-100 pounds
8. Are You Buying More Than One Monitor? No.
9. How Many Displays Can Your GPU Support Maximum? And what GPU and driver version are you using if applicable? Planning to use an RX 480
10. What Port Do You Want To Connect To? HDMI
11. Is This Monitor A Primary Display Or A Secondary Display? Primary
Here is one I have looked into. It is IPS which is nice. https://www.amazon.co.uk/IIYAMA-ProLite-XU2290HS-B1-Widescreen-Monitor/dp/B00HY77URI
That is too much. 100 pounds is the maximum and I don't really need FreeSync. Something cheaper would be ideal but I will consider this if I somehow get more money.
