Question I'm looking for a PC case with a hinged door side panel ?
Vineeth_55
9
Requirements:
ATX mid-tower
Decent dust filtration
The side panel needs to swing open like a door.
No fish tanks
Where are you located? What is your budget for a PC case? What is your preferred site for purchase?
To add, what are you going to stuff inside your proposed chassis purchase?
DarkFlash, Lian-Li, Montech, Vetroo, Aerocool are some brands that come to mind, that have tempered glass side panels on their cases that rest on hinges.
Requirements:
ATX mid tower
The side panel needed to swing open like a door.
No fish tanks
India, budget would be 9000 INR max.
Stuff inside:
Ryzen 5 7600 (using stock cooler)
Asrock Arc B580 Challenger
Asrock B650 PG Lightning ATX motherboard
This site and the majority of it's user base are located in USA, this is why we ask users for sites they have access to, so we can learn of what said users can get brands and products wise. One example is Deepcool is banned in USA, not in Asia.
Can I ask why you want a hinged side door?
no practical reason, I just like it.
I'll take whatever you can recommend and then decide after that
This isn't going to help any one of us apart from wasting time with the back and forth. Specify sites local to you and we'll go looking.
these sites are local:
https://www.primeabgb.com
Amazon is there but prices tend to usually be inflated
Latest posts
