Looking for a portable computer case. Please help!
Wraith9124
46
I often have to move between houses because my parents are divorced. Of course I've considered buying a laptop, but seeing the outrageous prices that are charged I'd rather build one myself. Please leave a reply below about good quality portable computer cases. All help is appreciated, thank you!
(I apologize if this was posted in the wrong section)
I had (and kind of still do) one of those Apevia Q-Pack cases. kinda cute, fits mATX boards, the power supply that's included isn't the best but it's alright. has a very handy handle up front. but most of it is aluminum which isn't as rugged as steel.
my current build is in an Antek ISK600, which is ITX. I like the layout since it doesn't shove the power supply above the cpu, meaning you can put on any cooler you want. and most not-insane graphics cards fit well, too.
I don't think there is a Micro ATX with grips like that. Honestly the one listed is your best get, plus the air flow is a lot better.
oh, the ONLY downside to that Apevia qpack or xpack or whatever it's called now is that you CANNOT use a tall cpu cooler. you can use liquid or a normal factory cooler or a low-profile deal.
see pic for example:
What case model is that?
C70 Military Green (Green)
Also want to point out it comes in black or white which are both $10 cheaper.
