Looking for gaming PC help, pre-builds and DIY.
michaelstephen1992
64
I recently bought a PC from fierce.co.uk, the brand is exile, CPU AMD Athlon X4 880k Quad 4 GHZ, RAM 16 GB, GPU NVIDIA 1050TI 4GB. I'm thinking of returning it because my CPU usage is going to %100 at times and also the disk is doing the same. My room feels very warm and the top of the case but the sides seem cool. I was wondering if for the price of £800 could I buy a better pc and where from and I'd also take into consideration building my own but I have no experience but would be willing to give it a try. Advice would be great because I don't know much at all but I'm a quick learner.
I'm more familiar with $ than £. But that sounds like more than enough to build a nice gaming PC. Basically, it is a matter of 8 or 9 components:
Case, Motherboard, CPU/cooler, RAM, PSU, Gfx card, Drive(s), O.S. (assuming you already have a monitor, KB, mouse)
Yes, you can do better than the pre-built you bought. Here is one I put together for $661 (~£500, I think)
Thanks for your reply.
What is the CPU like on that build? What games do you play?
Do you know if any options that are around £700, maybe a better CPU?
I built it mainly for resale. I ran some benchmarks but did not do any actual gaming. I'm selling it as new. It got a 2600+ score on Time Spy. But the CPU is way more than needed for the 1050 Ti. The i3-8100 won't bottleneck a 1060 6GB or RX-580.
I wasn't offering my machine for sale to you in GB (?), just using it as an example of what can be had for under $700 USD. In fact, I believe I specified US sales only. I'm sorry if I gave you the wrong impression.
As to your current system, I suspect the 860K is maxed out in multiplayer gaming. Especially on busy servers with lots of players. The 1050 Ti is a solid 1080p/60Hz card using high settings in most games. Medium in the most graphically demanding.
The 860K is a low IPC processor by today's standards. Unfortunately, that may be the max CPU your board will support. So upgrading it is probably not an option.
