looking for help for my pc build
Jaden1
Commendable
Sep 30, 2016
26
Hi
I wan't to build cheap pc build. I was thinking using those parts but the question will it work?
Cpu:AMD Athlon X4 860K 3.7 GHz QC (bought)
Motherboard:Colorful C.A68M-E Plus V15 for AMD A68H
Dddr3:8gb
Graphic:ASUS GeForce GT 730 Silent 2GB (bought)
Power supply:Mission SG GGP 1.0 550W with 80 PLUS certification
Chassi:Mission SG GGX 1.1 ATX
i dont see a problem with the system, seems to have enough power i will recommend getting a good heatsink i remember athlon being mini heaters and aside from it being a bit slow on games due to the GPU it should be fine.
