Looking for help with a best build 550-600$
Billy_13
94
Looking to make my own gaming pc not to tech savy anymore so I need helping putting one together I have about 600 at max to spend I want a build I can buy an use now an change an make better later. any ideas would be great.
an I would like something I can upgrade later. I seen this build for little over 600. but idk whats good an whats bad. its why id like help.
Case – Rosewill REDBONE ATX Mid Tower
Processor – Intel Core i5-4460 Quad-Core
Motherboard – ASRock Micro ATX DDR3 1600 LGA 1150
Video Card – Gigabyte GTX 960 Overclocked 2GB
RAM – Crucial Ballistix Sport 8GB Single
Power Supply – EVGA 500W
Hard Drive – Seagate 1TB
CD Drive – Asus 24x DVD-RW
That build looks pretty good, I would suggest a 550w power supply as it will not restrict you on future upgrades. A 500w will not be enough for the highest end graphics cards. Other then that you will be able to play pretty much any game at 1080p, high-ultra settings with a solid 60+ fps.
Awesome thank u for the quick response I'm hoping to order the parts here in a week or 2 is there a web sit by chance that looks kinda at multiple site to see what the cheapest to buy from. if not ill get off amazon.
If you are interested in overclocking then you need to get a K series CPU and a z97 motherboard. If you don't want to overclock, get an h97 motherboard that is not micro atx... I reccommend getting one by gigabyte, asus, asrock, or msi.
CPU: Intel Core i5-4460 3.2GHz Quad-Core Processor ($174.88 @ OutletPC)
Motherboard: ASRock H97 Anniversary ATX LGA1150 Motherboard ($70.98 @ OutletPC)
Memory: *Mushkin ECO2 8GB (2 x 4GB) DDR3-1600 Memory ($31.99 @ Newegg)
Storage: *Hitachi Deskstar 1TB 3.5" 7200RPM Internal Hard Drive ($43.00 @ Amazon)
Video Card: EVGA GeForce GTX 960 2GB SuperSC ACX 2.0+ Video Card ($189.99 @ Amazon)
Case: DIYPC Ranger-R4-R ATX Mid Tower Case ($33.83 @ Newegg)
Power Supply: EVGA 600B 600W 80+ Bronze Certified ATX Power Supply ($49.99 @ Amazon)
Total: $594.66
*Lowest price parts chosen from parametric criteria
Generated by PCPartPicker 2015-11-22 22:29 EST-0500
This build will let you play pretty much any game at 1080p, high-ultra settings. Things like RAM, HDD, and Case dont matter too much as far as brands go, so just get whats cheapest on the website you are ordering from. (The case should just be one you like the look of).
thx a lot with the build help I think ima go with that. is there room for upgrades later down the road. an on ur post the ram is different then in pc part list thing I like corsair should I go with it.
you can burn it to a USB stick on another computer then install it just like from a DVD.
You can use this program to put it on the USB, https://www.microsoft.com/en-us/download/windows-usb-dvd-download-tool.
You will need to download the ISO for the version of windows you are running and then get it on the USB with that.
here is what I would suggest for that price range..
Memory: G.Skill Ripjaws X Series 8GB (2 x 4GB) DDR3-1600 Memory ($44.98 @ OutletPC)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive ($44.89 @ OutletPC)
Video Card: MSI GeForce GTX 960 2GB Video Card ($179.99 @ SuperBiiz)
Case: Thermaltake Versa H24 ATX Mid Tower Case ($22.00 @ Newegg)
Power Supply: XFX TS 650W 80+ Gold Certified ATX Power Supply ($44.99 @ Newegg)
Optical Drive: LG GH24NSC0 DVD/CD Writer ($13.89 @ OutletPC)
Total: $596.60
Generated by PCPartPicker 2015-11-23 11:53 EST-0500
