Looking for smallest case for ASRock Z68 EXTREME4 GEN3
thinkmusic
6
I'm a new builder and probably went about it the wrong way but I want to find the smallest case I can for my ASRock Z68 EXTREME4 GEN3 motherboard. I have the following other items already:
SeaSonic X Series X650 Gold - Power supply
ZOTAC AMP! ZT-50702-10M GeForce GTX 560 - Video Card
SSD
1 TB hard drive
I'm really not planning on much expansion besides possibly another SSD when the price goes down.
Any suggestions on a small case would be great.
THanks,
Mike
Here are some of the smallest (high quality) cases I could find in the list that I have created:
Antec Fusion Remote MAX - 445x190.5x452 (WxHxD)
Antec Solo - 206x432x470
Antec Solo II - 205x440x470
Cooler Master Centurion 5 II - 202x440x485
Cooler Master Sileo 500 - 200x432x480
Fractal Design Core 3000 - 200x430x480
Lian Li PC-A05FN - 210x385x500
Lian Li PC-C60 - 445x182x410
I have also checked to make sure that they could fit the graphics card (which IIRC is ~21cm according to the Zotac website).
Thanks for the reply. I understand that I need great cooling and airflow but I'm looking for something a bit smaller than the average that would fit everything and be pretty cool. The other thing I didn't mention was that it would be nice to have something quiet. The Cooler Master HAF-X is 23 inches tall which seems pretty huge.
Yes! The video card you selected is large. The CPU needs a good after market heatsink. It is better to take these things into consideration now, and prevent future problems with space, high temps, etc.
Even a mid tower case may not be adequate for this type of hardware.
I would suggest a personal visit to some of the computer stores, and look at some of the cases, and the inside dimensions.
Dude you do not need a full tower for those components, look at the haf 912, coolermaster 690, antec 300 illusion, rosewill challenger.
here is a comparison list of mid towers.
http://www.newegg.com/Product/Productcompare.aspx?Submit=ENE&N=100007583&IsNodeId=1&CompareItemList=7%7c11-119-233%5eDM%2c11-119-197%5esCB%2c11-147-153%5esCB%2c11-129-066%5esCB%2c11-129-042%5esCB&bop=And&ActiveSearchResult=True&Type=1&Item=11-119-233
The rosewill is the smallest but not by much, the haf 912 is a great case which offers alot of room to work in.
Storm enforcer, storm scout, and the haf 912 are all very similar cases, they just have different external designs and slight differences.
There are millions of cases if you find one that you kind of like we can help you find others that are similar.
edit. Millions is a large overstatement...
Thanks, I'll look into that. Any specific suggestions of ones like that?
