I've always wanted to build my own PC, and a new job means I now have the funds to do so. I've tinkered with swapping cards out of existing builds etc, but building from scratch will be an entirely new experience.
I've attempted to spend some time reading up, consulting Custom PC and numerous forums, and have a nearly complete list of parts. i just need a little advice on the suitability of the list, the likelihood of the parts fitting together without trouble, and perhaps suggestions of improvements or places where I can reduce cost without gimping my PC.
Approximate Purchase Date: Now!!
Budget Range: Well the list below for the best prices I could find tops at around £1400, but would prefer to lower this a bit if I can.
System Usage from Most to Least Important: Gaming (primarily WoW atm), Photoshop stuff, Software Development, Surfing the net, probably some other stuff.
Are you buying a monitor: No
Do you need to buy OS: Yes
Preferred Website(s) for Parts: Well, I've been checking scan.co.uk and ebuyer.com mostly.
Parts Preferences: I;ve only ever had AMD/ATI combos, so would prefer an Intel/NVidia setup for this
Overclocking: Maybe
SLI or Crossfire: In the future perhaps
Your Monitor Resolution: 1920x1080 on 2 screens
Additional Comments: I've been trying to find a good combination of power, cooling and low volume - not sure if I've succeeded.
Why Are You Upgrading: Basically, my current PC makes WoW seem like the most demanding game ever made. 7 FPS is not fun to play at, rendering the MM part of MMO impossible since more than 3 people on screen maims my ability to play!
As it stands:
CASE - Coolermaster HAF X £124.99 @Amazon.co.uk
MOBO - Help me?! There seems to be an infinite list of options!
RAM - Corsair Vengeance Low Profile 8GB £35.79 @Ebuyer.com
CPU - Intel Core i5 3570K 1155 Ivy Bridge £165.14 @Amazon.co.uk
COOLING - Noctua NH-D14 Dual Radiator £56.86 @Scan.co.uk
PSU - Corsair AX860 £151.88 @Scan.co.uk
GPU - MSI N680GTX Twin Frozr 2GD5/OC £380.02 @Scan.co.uk
SSD - OCZ Vertex 4 256GB £164.70 @Scan.co.uk
HDD - Seagate 2TB SATA III ST2000DM001 £71.04 @Scan.co.uk
OPTICAL - Pioneer BDR-207DBK £58.31 @Scan.co.uk
OS - Windows 7 Premium OEM £72.84 @Scan.co.uk
PERIPHERAL - Razer Nostromo Gamepad £49.99 @Amazon.co.uk
Thank you in advance for any advice offered.
Overclocking: Maybe
As it stands:
