I am looking for the quietest fans that generate the most CFM. They are going to be used as intake / exhaust fans in my next build and I really want this build to be ultra quiet. Ideally i'd like them to be completely silent from where i'll be sitting ( about 1m ) and provide a combined CFM of 65-70 or more.
I was thinking Noctua NF-P12 , has it seems to have good reviews, however there are soooooo many other models of fan out there and i have ZERO experience with computer fans, basically as i was saying , i just want quiet fans, ill most likely buy 1 or 2.
The case i have only has 120mm mounting holes so im limited to 120mm fans.
Actually, i know there is the 140mm Noctua NF-P14 FLX that has a adapter to make it mountable on 120mm holes, however I am not sure if A) this fan is quieter dans the 120mm one, and B) if it will fit in my case as im guessing the depth of the fan should be bigger since it is 140mm ....
Thanks for your suggestions !
