Losing cable modem connectivity
dk4dk4
Frequently losing internet connectivity at the cable modem (cogeco).
modem will randomly reboot and reconnect to cogeco network.
Cable Signal Details (192.168.100.1):
Forward Path:
Signal Acquired at 453 MHz
SNR: 38.8 dB
Received Signal Strength: 10.4 dBmV
Bit Error Rate: 0.001%
Modulation: 256 QAM
Return Path:
Connection: Acquired
Frequency: 35.3 MHz
Power Level: 43.2 dBmV
Channel ID: 5
Modulation: 16 QAM
Cable modem was just recently swapped out for a brand new one. Problem continues.
Sample from the log:
Fri Sep 05 08:57:10 2014 Notice (6) TLV-11 - unrecognized OID
Fri Sep 05 08:57:09 2014 Critical (3) DHCP WARNING - Non-critical field invalid in response.
Time Not Established Critical (3) No Ranging Response received - T3 time-out
Fri Sep 05 01:05:40 2014 Critical (3) DHCP WARNING - Non-critical field invalid in response.
Fri Sep 05 01:05:25 2014 Critical (3) Received Response to Broadcast Maintenance Request, But no Un...
Fri Sep 05 01:04:53 2014 Critical (3) Started Unicast Maintenance Ranging - No Response received - ...
Thu Sep 04 22:54:33 2014 Critical (3) DHCP WARNING - Non-critical field invalid in response.
Thu Sep 04 22:54:07 2014 Critical (3) Received Response to Broadcast Maintenance Request, But no Un...
Thu Sep 04 22:53:35 2014 Critical (3) Started Unicast Maintenance Ranging - No Response received - ...
Thu Sep 04 22:53:21 2014 Critical (3) Started Unicast Maintenance Ranging - No Response received - ...
Thu Sep 04 22:53:20 2014 Critical (3) Started Unicast Maintenance Ranging - No Response received - ...
Wed Sep 03 14:19:56 2014 Critical (3) No Ranging Response received - T3 time-out
Mon Sep 01 09:56:13 2014 Critical (3) DHCP WARNING - Non-critical field invalid in response.
Mon Sep 01 09:55:48 2014 Critical (3) Unicast Ranging Received Abort Response - Re- initializing MAC
Mon Sep 01 09:55:35 2014 Critical (3) No Ranging Response received - T3 time-out
