Ok, so here's what I've got:
Phenom II 955 BE C3
Ultra X-blaster case
Ultra LSP550
WD Caviar Black 650GB
Gigabyte 890GPA-UD3H
2x2GB Blue Ripjaws set @ 1600mHz
Overclocked to 3.6gHz... idle temps are fine -- so I run Prime95. About a minute into the benchmarking a loud BUZZ (kind of a beeping noise) comes from my motherboard... and I can't pinpoint where exactly. When I STOP the benchmarking, the noise goes away. If I run the benchmarking on stock settings, there is no Buzz/Beep. The temps stay under 55C even under the full load, so I'm not sure why it's happening... Its a constant beeping noise, there are NO pauses.
Is this some kind of warning noise? Or is a cap that's screwed up on my motherboard. Everything is less than 2 weeks old... Please help!
Phenom II 955 BE C3
Ultra LSP550
