Question Low cpu performance and super low clocks on first launch
Dec 30, 2023
On initial launch for the day my windows takes forever to load(up to 5mins) after typing in passcode I have noticed that my cpu will run at 500MHz on said initial launch. Everything is fixed with a reset just trying to figure out why it would do this. I have also noticed my cpu doesn’t perform as it should in benchmarks scoring almost half of what it should in multithreaded benchmarks and won’t pbo boost past 5100mhz
Specs:
Mono: nzxt n7 b650e
CPU: Ryzen 9 7950x3d
Gpu: Radeon rx 7800xtx
Ram: Vulcan ddr5 2x16gb 6000mhz Ram
Psu: Thermaltake 850 gold psu
There are lots of drivers needing installing from your mainboard's manufacturer website, plus a few special AMD patches....
Mainboard's BIOS the latest? (Obviously it is recent enough to allow you to at least post with the 7950X...
Was this a 'swap mainboard/CPU/RAM' and reboot with an older Win10/11 install, or a fresh install?
This is an older win install with a swap ram mb cou and gpu, all drivers and updates are latest from amd and nzxt
New motherboard/new system requires windows reinstall.
If you try to avoid reinstall then you get this kind of weird system behavior.
Sometimes it doesn't boot at all,
sometimes you get bsods/crashes/bad performance
and problems with activating windows.
Reinstall.
And check cpu temperatures. Overheating will cause thermal throttling.
Reactions: Smakk
New windows install worked great I’ll have to see tomorrow if it has a slow start but I’m clocking to normal speeds now and performance is where it should be thank you
