Question Low FPS in Minecraft with shaders
Sep 25, 2018
Just got into playing Minecraft on a server with friends again after upgrading some hardware. I get anywhere from 100-200 FPS without shaders, but, as soon as I enable one, FPS drops to anywhere between 30-80 FPS with a lot of fluctuation. I have optifine installed, I have reinstalled java, I have allocated various amounts of RAM ranging from 2G-8G, I have reduced my render distance, played with v-sync and frame limit, I have disabled some AMD programs that were rumored to cause stuttering and FPS drops, I have taken discord off of its setting to use dedicated graphics, and I have tried all combinations of shader settings, and a few other things over the last week or so. I have googled this topic to death and have found nothing.
Specs:
OS: Windows 10 Home Edition
CPU: Ryzen 5 2600 @3.4GHz
GPU: Radeon RX 580 4GB (According to MSI Afterburner: Core Clock: 1350 MHz, Memory Clock: 1750 MHz)
RAM: 16GB 2666MHz (Considering overclocking)
HDD: WD 500GB, Toshiba 750GB
SSD: None
I play on the server with someone who has the R5 2600x and a GTX 970 and gets >100 FPS easily with shaders applied. It's just frustrating putting a bunch of money into a system for it to react like this; it should work well. Any help and/or insight is much appreciated. Thanks!
(So far I have only had low FPS in Minecraft if that helps solve the issue)
Try uninstalling and re-installing the game. Shaders GREATLY impact performance though, so this could just be the typical impact. Think of it this way: Each block in the render distance, even the ones buried in the earth that you can't see, has to be re-rendered with the shader.
What performance you get depends on the shader pack you are using. Did you install the shader pack through optifine? Don't expect great performance with a shader pack. They are often very unoptimized.
Tbh, I'd expect better performance than 100fps on normal minecraft. You said you were playing on servers. Your performance may vary a TON based on the server you are on, if that server is a minigame type server. Have you tried playing on a realm or singleplayer world to see if you get stable performance?
Wild guess, but most shaders I've seen seems to work better on Nvidia cards. Try going for a light weight shader pack if you haven't already.
