Low fps on crysis. noob needs help!
afrancies
24
I have a EVGA GTX560 superclocked 2gb and I get around 25fps on high settings. This dose not seem normal to me. I use r_displayinfo 1 in the command promt. for FPS
V sync on
2x AA
1080p
Specs:
HP h8-1230
AMD FX FX-6120 / 3.5 GHz (4.1Ghz Turbo)
10GB @ 1600Mhz
Antec 550W PSU
EVGA GTX560 Supercloack @ 907mhz core clock - 2048 MB 256-bit GDDR5 (with latest drivers)
HDD: 2TB 7200rpm
Im also using a physical CD is that matters...
I have Asus GTX 560 DCII which is very similar match to your Card except from different vendor. I could play @ 1920x1080 all settings maxed out except AA. My average frames are around 30~35. Sometimes dips 22
My sys is
I5 3570 + 550 W SMPS + 4 GB DDR-3 Corsair
Your card is a decent faster 2011 card, dont listen to others. I have played almost all recent games(2011 to 2012) and 95% of all games can be played with max settings except AA at most games. I believe either your CPU or HDD might be giving trouble. Try standing still (By looking at a foliage\tress) and check your frames. Disable VSYNC for demanding games always for cards like this.
You really think its the RAM? What would you recremend? I have 4 slots, so if I got two 4gb sticks what slots would I put them in?
thanks
maybe that was my sillyness
u probably already have it installed on your harddisk
do u have the latest patch of crysis too?
and i say, lower the resolution, or turn off AA and tell results
latest patch installed. I turned down the resolution and v-syncoff and AA off.
Getting about 35-45 FPS. I will still play with the settings.
Also put my slider to preformance mode in the nvidia panel.
Another questing is alot of my setteing are on "custom" mode on start up. I have to change the settings every time. why is this?
I see what your saying, thanks!
My sys is
