[SOLVED] Low Fps RTX 2080 Ryzen 5 3600 MW Warzone
Feb 13, 2021
My frames on Warzone has been not performing to it's expectation I'm pretty sure. My friend has a 1080 i7 8700k and gets me more frames on only this game. Does anyone know why, or a way to fix this. I manage to get around 90-110 frames on only 1080p on everything low. Please let me know if you had experienced this and or found a way to fix this.
SPECS:
RTX 2080
Ryzen 5 3600
16gb 2400 MHz Ram
1920x1080p 144hz
https://www.userbenchmark.com/UserRun/39810500
"2400 MHz Ram"
"Ryzen 3600"
Well that was a shot to the knee. Ryzens prefer fast ram.
Within the range of 3200 CL14 - 16 would be best here.
That might not be the only problem, but it's the most notable one.
SPECS:
RTX 2080
Ryzen 5 3600
16gb 2400 MHz Ram
1920x1080p 144hz
You need to turn off "DirectX Raytracing," OFF which is located under graphics/shadow and lightning.
Watch your FPS sky rocket afterwards, you must turn this off for WZ if you have an RTX card. You are very welcome!
