I’ve had this issue for more than a year now. So I recently tried playing Cyberpunk 2077 and I can’t seem to get the game to run correctly. I’m getting between 45-65 fps no matter what I turn the settings to in Cyberpunk 2077. Even if I turn the game to the lowest supported resolution and settings possible, I still get 45-65 depending on where I am in game. I don’t have any fps limits set anywhere and my monitor has a refresh rate of 155hz. If I turn down the game settings the CPU and GPU utilization also go down drastically instead of pushing for a higher framerate.
I remember being able to get well over 100fps with the same hardware at 1440p Ultra in this game about 6 months ago.
I noticed this problem too in other games like Spiderman and Control. I even have this problem in Fallout New Vegas and I can’t push past 65 fps even in it…the gpu utilization is less than 20% in the game.
I’ve done a fresh windows install, chipset drivers up to date, latest bios, latest graphics drivers, and no thermal issues whatsoever.
The issue started a little after I got a new cpu I think.
Benchmarks like 3dmark work like a charm and can even reach higher scores than what you would regularly be able to with my specs.
I don’t know what’s going on at this point. I have spent probably hundreds of hours trying to fix this to no avail. Please. I’m desperate.
CPU:5900x
Gpu:3080 ti
Ram:32GB corsair vengeance 3200mhz
Mobo:Asus ROG B-550-i
psu:Corsair sfx750
Ssd:Samsung 980 pro 1TB
CPU:5900x
Gpu:3080 ti
psu:Corsair sfx750
