Question Low GPU Usage and low FPS in PUBG ?
Oct 25, 2024
Does anyone know if this is normal in the video link I provided below.
I'm getting low GPU Usage and low FPS when I play PUBG.
Mobo: Asrock B660M - HDV
CPU: i5-13400F
GPU: RTX 4060 TI
RAM: 2 x16GB DDR4 3600Mhz
PSU: MSI Mag A650BN
I saw other people's videos with similar specs but they didn't experience gpu usage as low as mine.
However, the GPU usage can be maximized when running the Furmark benchmark.
View: https://www.youtube.com/watch?v=YqekCrXJjSM
Uff, Asrock calls it CAM (Clever Access Memory) and you can find it in "chipset configuration". Check the BIOS version, it is important that you do not have a very old version.
FYI
FYI
okay ill check later. then what to do if i have a very old version? ,
For your information, I just reinstalled the computer, did it not automatically update the BIOS version?
yes i already view it, 180hz then in game setting already turned off V-Sync and on Nvidia control panel already turned off V-Sync it must be arround 270-300 FPS on Apex in youtube i watch with same specs
Interestingly. You wrote that "However, the GPU usage can be maximized when running the Furmark benchmark". Does this mean that apart from PUBG, your PC's performance is comparable to other similar builds?
Edit: Maybe your MOBO VRMs getting too hot...
https://www.techspot.com/review/2424-asrock-motherboard-fail/
https://vk-com.translate.goog/wall-...l=auto&_x_tr_tl=en&_x_tr_hl=cs&_x_tr_pto=wapp
