Question Low noise fans for spec. sound requirements of a very silent pc with Ryzen >3000
Apr 30, 2020
4
hi there good day dear guys
i am currentyl looking for low noise fans for spec. sound requirements of a very silent pc with Ryzen >3000: i want to buld up a new desktop-pc with a low noise-sound.
so therefore i am currently looking for the best CPU cooling solutions (air and [[liquid]]) for a new PC systems - for a big form-factor build.
i am aiming for the ultimate low noise PC that doesn’t get noisy even under load:
therefore i need to choose the right CPU cooler: i guess that this is pretty important decision in any PC build or upgrade that can make a big difference in temperatures, noise and
all the coole i have had so far have been very loud. They should keep my chip’s heat under control, and sould not produce any noise pollution.
at the moment i am not very sure whether i want air cooling or a liquid-cooled AIO:
So i need some there things to consider - what to choose:
  • Big air coolers tend to be not as quiet as the liquid-coolers or fanless coolers.
  • Big air coolers tend to be expensive
  • Big air coolers tend to take up more internal space in the PC case, particularly when it comes to vertical clearance off the motherboard.
  • Big air coolers tend to be louder and less efficient at moving heat away from the choice of CPU and out of the chassis, though that’s not always the case.
  • Air coolers seem to cost less than AIOs, though that line is blurring as well.
do you have any tipps - how to proceed - what to choose: are there some tests online where i can see how good modern cooler are - how we can surpresss the noise of the fans?
questions that arise:
  • do you have some quick Tips for me. where to follow?
  • When choosing a CPU cooler, consider the following?
can i take into consideration to obtain a recent Ryzen 3000 CPU? with the 570 chipset ?!
some considerations:
If i am opting for a large air cooler, i just have to make sure to check clearances before buying the stuff.Big coolers (so called monster-coolers) with a damned low-profile models can some times bump up against tall RAM-sockets and besides this some times even VRM heat sinks sometimes. And the tall monster-coolers can cause clearance issues with the case door or window. That said i have to be very very careful: i need to be sure to check the dimensions and advertised clearances of any cooler that i take into consiceration before buying it.
so here you come into play: What do you suggest !? Many thanks for any and all tipp!
btw: see some recommendations of my friends .. about what are some of the best CPU Coolers in the year 2020: class Air-cooler
a. Deepcool Assassin III - the big Air CPU Cooler
2 × 140 × 140 × 25,0 mm
oil-
400 – 1.400 U/min
153,5 m³/h
1,8 H²O
29,5 dBA
4-Pin-PWM
distance 105 mm (analog 120mm-Lüfter)
b. Scythe-Fuma-2
1 × 120 × 120 × 25,0 mm
Hydr
300 – 1.200 U/min
36,9 – 113,7 m³/h
0,8 – 1,1 H²O
4,0 – 24,9 dBA
4-Pin-PWM
c. DARK ROCK PRO 4
with 100% load 24.3dB(A)
d. Noctua NH-D15
socket-ready: 2011, 2011-3, 2066, 1156, 1155, 1150, 1151, AM2, AM2+, AM3, AM3+, AM4, FM1, FM2, FM2+
formfactor: Tower cooler
cooler: yes
cooler dB(A): 19.2 dB(A)
cooler U/min: 1200 U/min
delta-air: 115.5 m³/h
air-socket: 4-pin PWM
measures
: 161 mm
: 150 mm
: 165 mm
i have read some texts here - to get a first insight - see below
freercurse
226
12
4,715
23
if you something really quiet for the CPU, there are some new fanless cpu coolers that recently hit a little while ago, they may be something you might want to look into.
LTT Video:
View: https://www.youtube.com/watch?v=9PJOrfpiVwE
Purchase link (different case 'cant find original') : https://www.scan.co.uk/products/streacom-st-db4-silver-compact-fanless-case-aluminium-bi-symmetrical-chassis-mini-itx-usb-30?gclid=Cj0KCQjw-_j1BRDkARIsAJcfmTFajYk4L7U-fnuwEtCDTpiq4qFZsF5dGGCXl-YMcE_SxvNQbolYuDIaAn7LEALw_wcB
then use a water block AIO GPU
