Hi,
I recently bought a pc and after a while I noticed that my pcie slot is running at low speed.
i3 10100f
Gt 730 Zotac 4gb ddr3
Gigabyte H410M H (rev. 1.x)
8gb 2666 Ram
Did a bit of searching and tried every recommend solutions like Resetting and updating bios, reseating cpu and gpu &... but the problem is still there.
Bios ( View: http://imgur.com/a/n4MTCW6
My graphics card as you see [ View: http://imgur.com/a/3tB58xf
] is supposed to use 8 lanes to transfer data but it is currently using just 2. I should mention that I don't have any nvme ssd installed on the board.
This leads to super low cpu load sometimes and i was wondering if there is something to do to fix this
I also couldn't find any options related to pcie's speed in Gigabyte bios .
GPU-z render test does not change the speed either
i3 10100f
8gb 2666 Ram
