[SOLVED] Lower CPU speed in CPU-Z
gogo7bg
Commendable
Sep 10, 2017
85
Ok so ive recently found out that my fx 8350 which is not overclocked with a hyper 212 Evo ( i dont think there will be any cpu throttling with this cooler ) runs at 3.39ghz and not 4ghz...and i am getting kinda confused. CPU-Z shows 3.39 but task manager shows 3.36. not getting confused by the difference between them but bc it should be 4ghz ,right? Tho task manager still shows that base speed is 4ghz. Also is there is anything else that should not be like that please tell me.
CPU-Z
View: https://imgur.com/a/VQKkfmN
Task Manager
View: https://imgur.com/a/yAhLYcI
Um I found the issue. It turns out that I had the minimum and maximum processor state at 99% in the advanced power settings tab ot Power options. Now that its on 100% the CPU is back at 4.00ghz.
I did the benchmark and it seems like its clocked at 3.36 and just doesnt move at all
I also tried oc-ing it to 4.2ghz (the mobo has that option) and it seems that it has boosted those 3.36ghz to 3.56ghz. bc the stock is 4.00ghz and the oc 200mz it makes sense but at the same time it doesn't...bc why would be clocked at 3.36ghz -___-
