Hello everyone, I'm completely stumped.
Here's my situation. I just bought a Alienware Aurora R7, Gtx 1070, i7 8700, 32gb ram, 1tb hdd segate hardrive and 16gb intel optane. I bought it used like two days ago, everything working fine. In my laptop, i have an ssd, and I could feel the difference in speed between ssd and hard drives, so I decided to buy an m.2 NVMe ssd for the new desktop computer.
Here's how I replaced the drives:
I've already tried pulling out the motherboard battery, and also re-arranging the sata cables (there are 4 slots,) and that didn't work either.
Please help. Since I just bought the PC, I have no info on the pc, I really dont care if i have to reset a bunch of times or anything. I just want to have my PC working with the new m.2 NVMe ssd and also the HDD. Any help will be appreciated
Edit: Here's the brand of the ssd:
"SK hynix BC511 NVMe 256GB"
Thanks, Kevin
- I unscrewed and took out the intel optane m.2 drive and put in the new ssd i bought. (SK hynix 256gb)
- Screwed it back in, and booted up the system. Windows install auto prompted and I installed windows onto the new ssd.
- I opened up windows, and checked file explorer to see if the drives were working, and only saw the new ssd(which means the new ssd works). The HDD could not be found in file explorer. I checked in BIOS and the HDD was seen there.
- After some research online, I realized i f**ked up, and should have removed intel optane first before i removed the drive.
- After figuring this out, I pulled out the new ssd and put back the 16gb intel optane m.2 ssd. I went into BIOS and clicked on a button that allowed me to remove the intel optane.
- After doing this, I pulled the intel optane m.2 drive out, and then put the new ssd back in. However, I was stuck on a "detecting media presence" screen, and then it wouldn't detect anything. I did some more searching, and read something about switching from RAID to AHCI. The new ssd still wouldn't boot up, and so I decided to re-install windows onto the HDD, to see if the new ssd would even be detected.
Thanks, Kevin
