Hey, My SSD is XPG Spectrix S40G.
Motherboard Asrock X570 Phantom Gaming 4.
Windows 10 system
Almost since I built my PC, which has been a couple of months, I ran into issues with my system crashing into bluescreen, after which the SSD was not detected in BIOS - I had 'boot from device' text line pop up, until I switched off power button on my case, and then booted back on. (Resetting didn't do anything, my SSD and boot priority was still gone.)
Issue is partially resolved since I migrated my OS to HDD, using Macrium Reflect. Used PC for 2-3 days and hasn’t witnessed a single crash. Before I had crashes at least twice a day and decided it’s finally time to do something with it.
It's rather obvious to me SSD may be the issue since I migrated OS - but I wonder if I use the warranty, how can I prove there were such issues, if my PC was crashing sometimes daily, sometimes not at all for weeks? Running tests in Victoria software doesn't show any disc errors. (Though Victoria software shows there were 36 unsafe shutdowns and 332 power cycles.)
(If I wipe my disc for eventual warranty, will the Victoria or such logs persist or does it reset?)
Some of the things I’ve done over months to fix this, or random things that came to my mind:
Thank you!
Windows 10 system
- BIOS was updated to the most recent version, which didn't fix issue.
- I ran SSD power cycle for ~1 hour according to some instructions I’ve found. No fix.
- I changed the slot for my SSD on the motherboard. It was in second slot and moved to first. No fix. (issue may even become more severe after 1 week?)
- I once had window's "Scanning and repairing drive" when booting my PC. Read some negative opinion about this SSD, someone said they witnessed that as well.
- I halfway thought it may be my system issue – because right after installing OS (Windows 10) after building PC, I used a lockscreen, showing mountains – it sometimes strangely still loads this wallpaper upon booting, especially 100% loads that old wallpaper after such system crash. After migrating OS to HDD, it still does that, so I guess it’s some inner system problem unrelated fully to crashing issue.
- At the beggining of building my PC I remembered, that SSD wasn't detected usually right after booting up PC. So I ran my PC and had instant boot menu popping up. It didn't happen anymore nowadays (nowadays only bluescreens). Back then had freezes/blackscreens and those instant boot menu's upon booting PC to work or game. (which were gone like charm if I switched power off and on).
- Most common bluescreen texts I got: „System thread exception not handled” and „Crticial process died”. It would never load up to 100%, it stayed at 0% until it showed boot menu.
Thank you!
