This is a long story, but I have to expalin everything so you can appreaciate the problem.
I purchased a bunch of hardware to build myself a new machine. Building PC's nothing new to me, so I ordered what I wanted:
Soyo Dragon Plus
AMD Athlon XP 2000+
RAID Max PSU
Everything worked fine with this setup. I later upgraded to a :
Soyo Dragon Ultra Platinum
Everything worked fine for two weeks, then the system wouldn't work. I thought I fried my CPU, because I unlocked it, or possibly a short. To confirm, and test I ordered:
Athlon XP 2100+
I put this processor in the machine and it still didn't boot. I was going to order more part to build a another system out of the Dragon Plus, so I went ahead and ordered the rest. I tried swapping everything, video cards, memory, HD's, and so forth, and still it wouldn't boot. So, I put my old motherboard back in, and tried angain, and it started to behave the same way. I removed everything from the case, and tried it outside the case to see if it was shorting tho the case somehow. Still the same. The mobo's will turn on and LED will work, but no video, or bios screen. I can hear the drive working, like it's loading the OS, but no video. Tried the new video card, but still no video. The only thing that I haven't swapped is the PSU, can a PSU cause a problem like this?
I'm completely stumped on this!
Best Regards,
Lonnie Bailey
Soyo Dragon Plus
AMD Athlon XP 2000+
RAID Max PSU
Athlon XP 2100+
Best Regards,
Lonnie Bailey
