I am helping a friend who has decided to make a custom PC. A mid range gaming PC with a fairly ambiguous budget. I am probably going to end up building most of it and I am choosing all the parts.
So far I have this:
GPU:Sapphire 290X tri-x 8 GB - http://www.newegg.com/Product/Product.aspx?Item=N82E16814202144&cm_re=290X-_-14-202-144-_-Product
CPU: AMD FX-8350 - http://www.newegg.com/Product/Product.aspx?Item=N82E16819113284
Motherboard: Asus M5A99FX PRO R2.0 - http://www.newegg.com/Product/Product.aspx?Item=N82E16813131851&ignorebbr=1
Now I have a few questions:
1. What case would you recommend? I may want to get a second GPU at some point, hence the 8GB version since Crossfire only uses 1 lot of memory (I think?) so I want at least 2 PCI-E 2.0 x16 slots. Apart from that just one with good cooling and a good look.
2. How many Watts will my PSU need to be? Also what brand is best for PSUs, I have heard good things about corsair but have had an FSP which has worked well for me but what would you suggest?
3. RAM, I think I will get G.SKILL Ripjaws X Series 2 x 4GB but is this overkill? Also is 8GB enough or should I get 16?
4. Cooling, what would I need with this rig? I have no experience in this area at all so I would prefer not to have to do water cooling due to my lack of experience but if I need to I could do some research.
5. Is there anything I missed, any component I missed or stuff I would want?
6. Have I made bad choices with any of my components, will they bottleneck, are they compatible, is there better at the same price?
Thanks in advance!
So far I have this:
Thanks in advance!
