Having added a Zalman water block to the 8800GTX in my 3.2GHz overclocked Intel QX6700 quad-core machine, the water temperature was pushing 60 degrees C and the Reserator was next to useless.
I quickly designed and made a fan cooled base for it, and it now works brilliantly with the Reserator barely getting warm even with O/C on CPU and 8800GTX.
Feel free to copy, and let anyone else know of this simple cheap solution to make the thing work properly
(last picture shows simple heavy cardboard flaps on each side to direct all the airflow over the fins)
Unit dimensions are 400mm long x 200mm wide x 80mm high.
plan is at:-
Full size pics in my gallery at
http://www.pbase.com/cdyckes/misc&page=all
Enjoy!
plan is at:-
Enjoy!
