Hi guys!
So i've got an internal Adata ssd which im trying to convert to multi partition flash drive to turn into a windows installation (7,10,linux) so i could get my life a bit easier so I dont have to use multiple usb drives .
The research i did on the internet didnt give much info the only thing i found out is that internal drives also known as "Fixed Drive" have just a bit of code (a 0 instead of 1) to tell pc if its a fixed drive or a removable drive and because of that you cant make them bootable as such!
so the program I use which is Rufus only recognizes removable drives.
if you guys know anything about if this is even possible to do or not please let me know
thank you in advance
