MAME on a portable hard drive?
G
Guest
Guest
Archived from groups: alt.games.mame (More info?)
MAME (and I think MAMEWah) seem to run directly from their folders,
without installing anything in the registry etc. Therefore, would it be
possible to install MAME, MAMEWah and roms etc onto a portable hard
drive? If you set up all of the paths using a mapped network drive
(say, X:) then you could plug the hard drive into any computer,
establish your X: and then your complete MAME setup would be available.
Does this seem right?
- Capn Stoobie.
> - Capn Stoobie.
Yep. You might have to fiddle with the computer's joystick settings, but
other than that, you can do it pretty easily. There are 4GB USB
microdrives out right now for less than a hundred bucks. I've thought
about throwing a few emulators and a bunch of roms on one to have
something to carry around in case a game breaks out or something. :)
GregoryD
Works fine using Mame32.
I've been using a portable HD/MAME setup for about 2 yrs. I use it also to
quickly put it back on the regular computer when Windows gets screwed up to
the point of no return.
Ed
"GregoryD" <hagar@hotmail.com> wrote in message
news😛an.2005.03.22.07.43.10.303068@hotmail.com...
>> - Capn Stoobie.
> GregoryD
>>- Capn Stoobie.
> GregoryD
Here's a thought:
1) Mount a USB hub /inside/ your USB arcade controller (X-Acrade
Solo/Duo or whatever)
2) Rerun the controller's USB cable inside the case
3) Run the hub's cable out through the hole for the controller's
cable
4) Plug the controller and your thumb drive into the hub (don't have
enough space on your thumb drive? Plug in one (or two) more and
point MAME to them - ROMs on one, everything else on another)
Voila! PnP MAME to go!
Thnik about it!
Dead_Dad
> Here's a thought:
> cable
> Thnik about it!
> Dead_Dad
Fabulous Idea!
I have a X-Arcade....... I might give this a go!!!!!
I would rather recommend buying separately a used 2.5" HD and a new 2.5" HD
USB case.
On eBay, I think you can get more than 40 GB with 100 bucks total.
AS
> USB case.
> AS
*oooOOOooo!* Change 'thumb drive' to 'great big USB drive' in my 'PnP
MAME-to-go' idea. Sweeeeet.
Thnik about it!
Dead_Dad
Dead_Dad's last words before the Sword of Azrial plunged through his body
were:
>> USB case.
Also, if you go with a 3.5" drive and casing, you can get it cheaper yet
.... after inserting a credit, tat-2 <tat-2@rcn.com> leaned forward and
saw...
[top-posting corrected]
MAME32 writes initial settings to the registry, though, whereas MAME
keeps its settings in a local .INI file (I think) - which means MAME32
is less portable.
"It's well past midnight as I lie in a semi-conscious state.
I dream of people fighting me..."
* 'Dungeon' Dave wrote in alt.games.mame:
> saw...
> is less portable.
Reg entries have been removed in favor of INI files. Happened a few
versions ago.
David
Aberdeen was so small that when the family with the car went
on vacation, the gas station and drive-in theatre had to close.
> cable
I'm french, and there is something i can't understand in your project,
do you have photo , please ? (easiest way to understand) 😉
>> cable
Before (To computer)#
| #<-USB cable |
| | Controller | |
| | Main | |
| | Board | |
After (To computer)#
| ---------------- | | #<-USB cable |
| | | | USB Out#============# |
| | | | Hub | #=========# |
| | USB | | | # # |
| | Hard | | In | # --------#----- |
| | Drive | # # # | Controller | |
| | | | Main | |
| | | | Board | |
Clear enough?
Thnik about it!
Dead_Dad
On Mon, 28 Mar 2005 09:40:43 GMT, Dead_Dad
>>> cable
>| #<-USB cable |
>| | Controller | |
>| | Main | |
>| | Board | |
>| | | | Hub | #=========# |
>| | USB | | | # # |
>| | | | Main | |
>| | | | Board | |
>Clear enough?
Almost like being there ;-)
"Dead_Dad" <XXXspamtrap007@yahoo.comXXX> a écrit dans le message de
news:viQ1e.821341$Xk.657774@pd7tw3no...
> >> cable
> | #<-USB cable |
> | | Controller | |
> | | Main | |
> | | Board | |
> | | | | Hub | #=========# |
> | | USB | | | # # |
> | | | | Main | |
> | | | | Board | |
> Clear enough?
> Thnik about it!
> Dead_Dad
OOOHhh YEESS !!!
like a photo,
you're great,
Thanks !!:)
it's what i though, but was unsure @_@
news:fqa0e.762071$6l.232980@pd7tw2no...
> >>- Capn Stoobie.
but
> > GregoryD
> Here's a thought:
> cable
> Thnik about it!
> Dead_Dad
and a mini PC (itx ?) inside the X-Cade ???? @_o
what do you think about it ??
just need to plug on TV or monitor , and power
i dream (?)
TrucMuche's last words before the Sword of Azrial plunged through his body
were:
> i dream (?)
Someone did something like that. They took a Sega Dreamcast two player
arcade stick, and wedged in a mini ITX setup in it. got the link somewhere
around here
>>>> cable
-----8<-----
>>Clear enough?
>>Thnik about it!
>>Dead_Dad
> OOOHhh YEESS !!!
> like a photo,
> you're great,
> Thanks !!:)
No problem. Ah, the wonders of DOS Navigator.....
Thnik about it!
Dead_Dad
>>>>- Capn Stoobie.
> but
>>>GregoryD
>>Here's a thought:
>> cable
>>Thnik about it!
>>Dead_Dad
> i dream (?)
I thought of that about ten minutes after I posted. <G> Here is a
low-rise TV output card ( http://tinyurl.com/4pxag ) that can be
butchered to reduce its height while still offering both composite &
s-video connectors. )You can also use a right-angle adapter
( http://tinyurl.com/4g3vy ) or riser card ( http://tinyurl.com/6ubsc )/
( http://tinyurl.com/6gmgr ) to reduce height.)
I found it while trying to find a link to a hard-cover sized pc made by
Shuttle. I also came across this little beauty
( http://tinyurl.com/5polc ), which is making me re-think building a
cabinet. Maybe I'll just place one beside my amp, under my 56" DLP TV
and just build an arcade /coffee table/ with one of those swing-up tops.
(Well, a guy can /dream/, can't he? <G>)
Thnik about it!
Dead_Dad
