Manually controlling 4 pin cooling fans
Morris123
32
Hi everyone,
Currently I am looking for some information. I have 4 fans with 4 pin connectors. These are capable of PWM control by the motherboard. However, I want to control them manually with a potentiometer. What is the best way to go about this? I have seen several guides and PCB’s capable of turning 3 pin fans into manually controllable fans, or even regular 4 pin fans. My fans are already 4 pins and I just want an external knob to control them, what is the easiest way to accomplish this? Thanks in advance,
Morris
The wires and functions of a 4-pin fan are:
Pin #1 (Black) Ground
Pin #2 (Yellow) +12 VDC fixed
Pin #3 (Green) Speed Pulse Signal
Pin #4 (Blue) PWM Signal
The signal in Pin #3 is a series of pulses (2 per revolution) generated in the motor and sent back to the mobo on this line for counting so that it can display the motor speed. This signal is NOT used to control the speed. Often mobos will monitor this line in case it shows no pulses, in which case it will issue a warning of fan failure.
The signal on Pin #4 is the PWM signal from mobo to motor. I believe it is a 5V signal like a square wave (it is either on or off) BUT not "square" in the sense that its % On time is not always 50%. Its % On time is what is varied to control flow of...
Hi, Thanks for your reply but alas it is not that simple. At the moment my PC no longer contains any 5.25 inch drive bays as i have made a custom wall mounted PC see here:
link to the whole build here: http://
Furthermore, getting a fan controller will just modulate the voltage or even do pulse width modulation. I just feel like this could be a lot simpler since my fans all ready have 4 pins connectors.
If you connect a 4 pin pwm fan to a 3 pin header, you will lose the pwm control, and the fan will run at full speed.
If that 3 pin connection has a rheostat control, then you can fine tune the rpm.
For a single fan, the zalman fanmate 2 or similar will do the job.
More likely with 4 fans to manage a front panel controller will do the job.
Here is an example:
http://www.newegg.com/Product/Product.aspx?Item=N82E16811990008
Thnx for your reply. However as i showed in my previous reply it will not be possible to put a drive bay fan controller, and i feel it kind of defeats the purpose of inherently controlled PWM fans. I am rather thinking of adding a simple potentiometer on the front of my pc to control all 4 fans. Like this
You should be able to use a pot with a circuit board but your going to have a hard time finding one over 4 Watts so it would depend on the fans if you needed to use 1 or 2. You would only need to use 2 pins on the fans.
Depending on how low you need to cut the volts down would very the amount of resistance you would need.
That would work.
You will also need to do some wiring so all 4 fans can be ganged together and a psu molex lead to supply the 12v voltage.
Would you be adjusting all 4 fans in sync, or would you be wanting to adjust them individually?
In the latter case, you would need 4 such rheostats.
If this is a one time adjustment, you could use one or more fanmate 2 located inside the case:
http://www.newegg.com/Product/Product.aspx?Item=N82E16835118217
What geofelt said about 4-pin fans on a mobo 3-pin header is wrong. 4-pin fans have a backwards compatibility feature so that they DO work under Voltage Control Mode on a 3-pin header. In such a case, the fan receives NOT a constant 12 VDC on Pin #2, but a voltage that is changed by the mobo port. It also does NOT receive any PWM signal to modify the voltage supply, so it just does whatever the voltage allows. Thus, you CAN alter the speed of a 4-pin fan by changing the voltage supplied to its Pin #2. (Pin #1 is Ground.)
The best way to do this is with a pre-engineered third-party fan speed controller because all the fancy design requirements have been done for you. But you want to DIY, so here's an outline of what you need to do.
1. Determine how many fans you will run together in PARALLEL from this one voltage source.
2. For each fan, get its rated current flow (or Wattage rating) at full speed with a 12 VDC supply. Calculate its individual current if necessary.
3. Add those currents because your several fans are in parallel. This is the max current at full 12 VDC supply when they are running. You should realize, however, that when they all are starting up from stalled, the momentary (1 to 2 seconds) current will be about three times that. However, this factor will not really influence a lot your power rating calculation later.
4. The reality of fan motors and supply voltage is this: at some reduced voltage (often between 5 and 6 volts, but could be higher on an older fan with bad bearings) the fan will stall and will not start up again until the voltage is raised enough. To start a stalled fan you need to supply at least 7 VDC for most units with good bearings. So, your design should somehow prevent you from giving the fans less than 7 volts. Maybe your variable resistor should have a mechanical stop affixed to it, or maybe you can simply buy a resistor whose max resistance provides this limit for you..
5. What you really plan to do, I believe, is install in the circuit in series with the motors (paralleled as as group) and the voltage source a variable resistor. The units often used for such things are commonly called "pots", short for Potentiometers, but a true potentiometer is a different circuit function and is wired and loaded differently. Still, it is the same type of component.
6. Start with the two extremes to do your calculations. We will assume that the voltage source you use (a 4-pin Molex output from the PSU) can supply well more than the total current needed by all your motors, so we will not worry about that supply voltage. First, the full-speed case of NO resistance from the variable resistor and full 12 VDC to the fans. You can calculate the total current through the fans (the sum of their individual currents), the total Wattage of power being consumed by the motors, and the apparent "resistance" of that group of motors from the Voltage and Current values. For subsequent calculations you can use that effective "motor resistance" even though, in truth, it will vary somewhat as motor sped changes. The variations will not be huge and will be ignored for purposes of our calculations. For this first case, you can assume that the resistance of the variable resistor is zero, and hence the power dissipated at that component also is zero.
7. Next extreme is the minimum voltage you will supply to the motors, say 7 volts. Thus the voltage drop across the variable resistor must be 5 volts. Using the "motor resistance" calculated above, calculate the current that must be flowing through those motors with a 7 volt supply. That same current must flow through the variable resistor. So now you can calculate two things for it: the resistance required to drop 5 volts across it with that current flow, and the power being dissipated (and converted to heat that must be removed) in that component. Now you have one limiting set of performance requirements for the variable resistor - its maximum resistance and a power rating.
8. Now, pick a few more voltage situations through the planned range - say, motor supplied by 6, 8, 9, 10 and 11 volts. Re-do the calculations as above to estimate the resistor value but, most importantly, the power being dissipated in it at that setting.
9. Now survey your results. You will need a variable resistor with a maximum resistance as calculated in step 7 (or maybe a bit more), and a power rating better than the max power being dissipated in those several scenarios you calculated.
10. Don't forget to use the maximum current flowing in the circuit (very likely the starting current, estimated to be at least twice the full-12-volt current) in choosing the gauge of the wiring you will use.
11. The variable resistor you buy probably has a power rating that assumes the heat will be removed simply by ambient air flow in the vicinity (but verify that) so you probably do not need a fan to blow over the resistor. However, you DO need to ensure it is in free air and not enclosed, AND that its mounting system can stand up to a hot component. You also need to recognize the physical size of the unit to mount it.
Third-party fan speed controllers do this job differently so they look quite different from simply a large variable resistor, and they dissipate less power (thus generating less waste heat) than your system will.
Hi,
first of all thanks for all the replies, this is exactly the reason why i love Tom's Hardware.
@Zerk2012 I know what you mean with the case of using solely a pot, that wont work, as for the fan is use see this link: http://
@geofelt I was indeed planning to add all the fans together and have one control knob, since it is not very usefull to be able to seperately adjust the fan speeds when all the fans are attached to the same radiator. Also since the fan i will use are 3,6 watts maximum the Zalman controller is only powerful enough for 1 at a time.
@makkem indeed, thanks
@madmatt30 The one you showed is for 12 to 24 volts but i see your point, that indeed looks nice as well.
@Paperdoc Thanks for your complete guide on how to manually make a fan controller trough voltage adjustments. I do very much appreciate it.
a note to all:
All of your suggestions are very good and will probably all work. Initially i was hoping to actually work with just the control line of the 4 pin fan and leave the power fully connected and thusly adjust the fan speed as the motherboard does, however this seems less and less to be a possibility. i shall now focus on doing the fan control with voltage regulation and ignore the 3rd and 4th line on the fan connector. Thanks alot for all your efforts!
BIG caution for you. In a previous thread I was part of, others posted strong notes from the makers of 4-pin computer case PWM fans. Now, PWM modulation of power flowing to a motor has been used for some time. HOWEVER, those readily-available systems provide a pulse-modulated supply to a relatively simple motor. The so-called "PWM fans" for computer case ventilation are quite different. Inside the latter are printed circuit cards that accomplish at least two major jobs: they use electronic switching to provide a simulated commutator in a brushless motor, and they use a separately-provided (via Pin #4 of the connector) PWM pulse signal to do their own modulation of the constant 12 VDC supply in Pin #2. These motors should NEVER be supplied with the kind of already-modulated DC supply that traditional PWM controllers provide because they depend on correct input voltage and PWM signal (separately) AND their internal components can be damaged by pulses and noise in the incoming voltage supply that is used for ALL components (not just the motor winding). So, do NOT use a common PWM Motor Speed Controller to try to control the speed of a computer-style PWM fan. Further, do NOT use the common types of lighting brightness control units intended for room lights or LED's. These devices also provide very spiky interrupted voltages that are likely to damage a computer fan motor. Even 3-pin fans that operate on Voltage Control Mode and are designed for reduced DC inputs on Pin #2 still use internal circuits to simulate a commutator system, and hence are subject similarly to damage from noisy power containing spikes.
Wow, thanks Paperdoc, this is very useful information. So if i want to control a 4 pin fan i should not be using a PWM motor speed controller but rather a voltage controller? Do you know exactly what goes through the 4th control line of a 4 pin computer fan? Is it externally replicable? Thanks alot.
The signal on Pin #4 is the PWM signal from mobo to motor. I believe it is a 5V signal like a square wave (it is either on or off) BUT not "square" in the sense that its % On time is not always 50%. Its % On time is what is varied to control flow of current from the 12VDC supply through the motor (via a small controller chip inside the motor housing). The more time the current actually flows, the faster the motor runs. I do NOT know details, so you'd have to find that if you want to create your own PWM signal.
There may be an easier way for you to do this without re-engineering the controls yourself. You CAN use the mobo's SYS_FAN port(s), but not in automatic mode since you prefer to DIY. And since you want all the cooling fans to operate under one control, you will need two things:
(a) A utility that runs under Windows and gives you access to fan control settings - this usually is included on the CD of utilities that came with your mobo. It will allow you to pick any of your mobo SYS_FAN ports and set its output (fan speed) to a fixed value of your choosing, also giving you a display of the fan's actual speed based on that pulse signal.
(a) A 4-pin special type of splitter also known as an adapter like this:
http://www.newegg.com/Product/Product.aspx?Item=N82E16812423165&cm_re=4-pin_fan_splitter-_-12-423-165-_-Product
Most mobo fan ports can power up to 2 fans, but you have 4. This adapter does two three things for you. First, it gets power for all (4) of its fans from a 4-pin Molex output of the PSU (can power MANY fans), and takes no power from the mobo SYS_FAN port. Secondly, it picks up the PWM signal from one mobo SYS_FAN port and shares that to all 4 of its fans - this does not overload the PWM signal. Third, it ensures that of its 4 fans, only ONE gets to sent its speed pulse signal back to the mobo (to avoid problems with the counting circuits) - the speeds of the other three simply cannot be monitored. That also means that possible failure of any of those three unmonitored fans cannot be detected for you - you have to check from time to time.
If you do it this way, you will have your manual control of all 4 fans as you wish, without having to design a controller system (you use the one already built into your mobo) and without having to install a third-party fan controller unit in a non-existent case.
Thanks alot once again Paperdoc. You provide me with the information i need.
