masterair ma410m wont fit am3+ even though it says it will
Jun 7, 2018
9
trying to install a masterair ma410m to a am3+ and the screws are to short to reach the stand off even though it claim sit should fit
ive checked the manual and watched a video the nuts that the cooler mounts to are not long enough to reach the screws on the cooler mount they are not on backwards ive also checked that as well
you use the provided plate and remove the oem one from board since on it goes a screw that croos in the hole and then little knob on it the the amd bracket scew to the cooler base and the screws of thos bracket screws in the knob ones could you post a picture of you set up on cooler fins and board .
