G
Guest
Guest
Archived from groups: alt.comp.periphs.mainboard.asus (More info?)
Hi all. First time post here (kinda rare when I have a tech question ;p).
I have an asus A8V8X motherboard, currently running an xp2100.
Here are the cpu specs (and link to full specs):
http://uk.asus.com/prog/spec.asp?langs=11&m=A7V8X
Processor: Socket A for AMD®: Athlon XP/ Athlon/ Duron up to 2.4GHz+
Thoroughbred core CPU ready
So it can run up to a 2.4Ghz chip (or over?), the FSB goes to 333mhz, so I
guess its pointless getting a chip which does more..
This is the chip I was thinking of getting, problem is it has a barton
core...will this fit onto my mobo (and work)?
http://www.scan.co.uk/Products/ProductInfo.asp?WebProductID=57349
AMD *Retail* Athlon XP 3000+ *333 FSB* Barton (2.17 GHz) with AMD Heat Sink
Fan
If not then I guess I need to get a lesser chip, or upgrade my mobo (which
is pointless atm as I cant afford a PCI-E card yet, and dont want to invest
in old tech, a single cpu doesnt matter, as can keep this machine together
when I upgrade next year).
Thanks for any advice, if I have missed any detail, let me know and will
post what you need 😉
Fan
