Maximus VIII Hero with H110i GTX -- Should I plug into cpu fan header or pump header?
chrislocho
With the above configuration, I have failed POST by attaching it originally to the pump header, but now am using the normal cpu fan header.
Should I change it back ? And if so, do I disable the error in BIOS?
Also wondering what the sata cable from the H110i is used for, as the manual does't tell me to plug it in, but I did it anyway.
Thanks in advance!!
Chris
okay, so I just installed by h100i gtx in to the same motherboard that we share.
I don't know how different they are but this is what I did.
I plugged the 3 pin from the pump into the mobo right next to where it says water pump.
The 2 fans from the radiator, I plugged next to it.
there was another wire that came attached. It was like an extension fan or something. I left it unplugged.
The usb cable is attached in the pump and to the motherboard.
