Memory Clock Speed
Chaqui
27
Specs:
ASUS X455LJ I5-5200u 2.20 ghz (Turbo Boost till 2.7 ghz)
8gb ram ddr3l
500GB HDD
NVIDIA 920m GPU (latest update)
I had this issue about my laptop that on every high graphic games like PUBG, fortnite, watch dogs and the like, I had this fps drops or stuttering like for example 50-60 fps then suddenly 20fps for a sec then goes back again. Even though I set it to half refresh rate or 30 fps it still happens. I've tried a lot of "fix" from the internet also youtube still uhhh 🙁 But I came to the part that I tried to experiment something with my CPU setting it to ranging 1 to 1.2 ghz since I just came up to my mind that I knew my GPU also runs at 900mhz to 1.1ghz so I just liked it balance. Eventually, the fps drops is gone. Any tips using it at full speed 2.2 ghz without stuttering?
well first of all those pc specs are definitely not the best for playing PUBG or fortnite, overall if you are playing on a laptop no matter what you will recive some preformance issues. sorry dude. 🙁
