Ok guys I have a sneeking idea I know what is wrong but I want to hear what people think before I go out and purchase another cpu. Yesterday I woke up and logged on my computer to find out it registering 8 gigs of ram instead of 12 gigs. I at first thought it was the motherboard because it did not matter which stick I put in the first or last channel it did not work. I tested all the ram in the other channels worked fine. The ram is mushkin 998675 which has been working fine since sept 08. So I called asus up told them what was going on and they rma me a new board. Got the new board put everything back together and same problem will only register 8 gigs of the 12 gigs I have. but with the new board they sent me its the last 2 channels are what are not working. I talked with a intel rep in online support and he informed me it was possible that the memory controller is failing on the I7 940 I am using because the memory I am using is 1.65v and its only rated for 1.6v. Thought this was humorous since mushkin packaged this for the I7 and when it first came out they had stated 1.65v was the cut off but I am seriously thinking that is what is wrong here. Not the motherboard. Have any of you run into similar issues recently? BTW my system had run slightly o.c. from sept 08 til yesterday with no issues then this happened. I am tending to beleive its chip with 2 boards same problem. Please let me know what you guys think or maybe solution I am not thinking of here.
