G
Guest
Guest
Archived from groups: alt.comp.periphs.mainboard.asus (More info?)
When I had first decided to build my pc, I had no or very little desire to
overclock and was looking to buy Crucial ram. However, after browsing
around I have suddenly caught the OC bug. Several reviews have indicated
that while Crucial makes good quality and stable ram, it does not overclock
well. I have now become interested in Corsair XMS memory to be used on my
P4c800-e dlx board.
The question I have is, is there any difference between a chip with a lower
speed of say ddr400 with low latency versus a chip with a higher speed such
as ddr433, 500 etc but with no LL, considering all things being equal such
as capacity, non-ecc, etc.
Just for the sake of comparison these are the latest prices I've found at
Zipzoomfly.com:
Twinx1024-3200llpt $308
Twinx1024-3700/pt $310
Twinx1024-4000pt $310
They have the DDR550 and higher, but is more than I am willing to spend.
Which of the above choices is the best "bang for the buck" for my MB.
I will be using a p4 3.0 Northwood if that makes any difference.
Thanks in advance for your help.
P4c800-e dlx board.
Zipzoomfly.com:
