Memory speed
ezzlar
55
I own a Powercolor 9600 PRO, 128 mb 400/680mhz. But in tests like Mark3d and Aquamark it says that my memory speed is 297mhz, shouldnt it be higher?
Are you sure it isn;t a 9600 PRO LT or "Lite"?
I hear those have reduced mem frequency.
Radeon 9500 (modded to PRO w/8 pixel pipelines)
AMD AthlonXP 2000+
3dMark03: 3529
Take that mofo back and freak on whoever sold it to you.
That's your only option, man.
AMD AthlonXP 2000+
3dMark03: 3529
Just to clarify in case you don't know, the memory is DDR (double data rate) so your 297 Mhz is really the equivalent of 600 Mhz... or that's how they advertise it anyway.
Still, if it's advertised at 640 Mhz then you should be running about 320 Mhz.
It's weird that they would advertise it at 640 though, because the 9600 PRO spec is 300 Mhz DDR (600 Mhz effective).
AMD AthlonXP 2000+
3dMark03: 3529
