https://www.gskill.com/specification/165/166/1536651750/F4-3000C14D-16GTZR-Specification G-Skill 3000Mhz ram. I recognize that only one 8GB ram stick runs the supposed XMP profile?!
No, all your sticks run at the same 1833MHz DDR speed. You're confusing it with your CPU idle/base/MC boost/SC boost clocks.Any suggestions to why the memory is stuck at 1866MHz, The task manger shows that the memory sits at 1866Mhz. I currently have 8GB x 4![]()
Did you only set the speed and not adjust the timings or voltage? I would retry 2933 at CL16-18-18-38 1.35v. Leave the other timings on auto just to see if it will even work. Then run memetest86 for at least 1 full default test pass.Well, thankyou for all your reply's. I've finally sorted the issue. Loading the XMP profile I realised the 3000MHz was not possible even said advertised at 3000MHz, instead I lowered the frequency at each set speed.
At 2933MHz the computer booted and all was good, until every program started crashing. Back to BIOS...
At 2800MHz same problem.
At 2666Mhz same problem.
Therefore I hit an ultimatum at 2400MHz for the computer memory to be stable I believe. Talking DRAM Voltages and such.
For now I will run the memory at 2400MHz, however if the problem persists I will drop the frequency value to 2133MHz.
Thanks for the input, its very much so assisted the solution, anymore input would be much appreciated.
